RC10B4.1 FT/WC
#8716
Just glue the servo saver down , the plastic bends and will still work just like a saver..
#8720
#8721
Yes, but unless you're a lot worse than a typical sportsman driver with an overpowered 4x4 SC truck and can't make a lap without hitting something, I don't think you have anything to worry about. I've been running mine glued on both my B4 and SC10 with no ill effects, yet.
#8723
#8724
8m B4.1 has all the other's rushing to catch up ...
Its the best 2w bug ride you can get ...
#8726
I would consider myself average. That being said, I did break a glued rack landing off-axis on one of the larger jumps (pretty big quad) at a local track.
#8727
Bottom line on all b4/t4 sc10's if your not using a glued steering rack you are not getting proper performance Period! It's a must do! If you still crash a lot, then I'd say u better hold off for a moment lol.
The racks will break often when glued if you wreck the right way. Which is precisely why the team is using the all 1 piece alum rack if they can find them. I got a couple of them, and they are great!
#8728
Even in the hands of a baddie like me, it goes where it's supposed to.
Oh hey Cherry,wanted to ask... how much does the cold affect your shock oil decision (if at all). Was at a track that had ambient air temp prolly in the mid 50's and was thinking I should go 5wt lighter all the way around. Then again I just said eff it and wheeled it
#8729
Other than two posts before me, is the glued servo saver or the aluminum steering rack a big difference? and what do you mean by glueing the servo saver?
#8730
I dont feel it but the front end is kinda worn on my car no to bad, but theres nice space between arms, hubs etc. Losi guy told me it hurts coming out of the corner and it might wander... REALLY? I would like to replace my front end and try but I dont wanna ruin it. Still need to get carbon arms tho
