SC10 4x4 Thread
Looks purdy , shit cheap even...... but ....... seems like only one way to run it. All the way forward or back as it uses the chasis as a back suppot for the lipos to secure against. not much tuning or adjustment options.
This is total first look rambling of a old slow guy at midnight. Maybe they have done enough testing with the new whammy mega bling chasis ( yeah i want one , but cant justify 100 bucks, as 100 in track fees will probably make me faster than the chasis will) and that is the optimum set up , but I know with my mantis work mount (that has the capability of fore and aft movement with no extra holes drilled ) i will move placement of packs in different locations for steering tuning
Like i said it sure is purdy and makes that fancy center look even fancier
o&s
o&s
They're swearing it's a Sheet of Concrete now with the Exotech. It doesn't bother 'me' being the chassis brace guy, cause I was only helping out against a certain someone. I think that it sure does a good job but shrug, I won't know myself without getting one, and we all know that's not happening.
But it was giving me something to do on these lonely nights! /eagles
with the exotek chassis not only does the chassis have no flex but the belt tunnel as well has no flex, stays straight and true, with the original chassis with no brace i could see the belt tunnel flexing outwards, since having the new chassis the tunnel has stayed straight. for those not wanting to fork the 100 bucks out, go with a chassis brace, those of us who did fork out the 100 are also not only using it for the brace but the extra added weight vs using lead weights.
a car needs a bit of flex when you are running it on mid/low grip tracks.
The original plastic chassis had a bit to much flex, but can be easily taken care of with a chassisbrace
you guys crack me up.
someone asks if the exotek chassis needs the chassis brace, and the only ones who says yes are the guys who dont have nor have tried the exotek chassis
let me put it this way, NNNOOOOO, you dont need the chassis brace. and to all the speculators, the exotek chassis has me with traction in ALL track conditions that i have encountered. take this as empirical data, not speculative,
when a track has lower traction, you want your truck to be a bit more flexible,
tis alu chassis piece will give more traction for sure but mostly becouse it lowers the cog not becouse it makes the truck stiffer
Think I'll just stick with my Mantis mount, and brace for now. I do like the extra weight of the exoteck, but I can't justify it "yet".
Does mantis make a saddle pack conversion that works with the exoteck chassis, already bought and installed chassis so i need to figure out something pretty quick or im not gonna have a truck to run over christmas
Personally still running the original original plastic everywhere and it is holding up to the abuse, except for the suspension arms....those bend like wet spaghetti...but no aluminum options for those that I have seen....
5Likes
