exhaust sound
Old 12-02-2011 | 05:21 PM
m33g0's Avatar
Default exhaust sound
How to make the exhaust sounds like those hks exhaust with deep bass rather than the high pitch sounds?thanks bros !
m33g0 is offline
Old 12-03-2011 | 03:37 AM
Bigger volume
Roelof is offline
Old 12-03-2011 | 06:52 AM
m33g0's Avatar
Sorry i don't understand.
m33g0 is offline
Old 12-05-2011 | 01:05 AM
asw7576's Avatar
Impossible
asw7576 is offline
Old 12-05-2011 | 02:32 AM
m33g0's Avatar
Originally Posted by asw7576
Impossible
thanks if cant make it sounds deeper..how about making it more quiet as i dont wish to disturb other people knowing that i might as well get a ep car but i like still perfer the smell and smoke !
m33g0 is offline
Old 12-05-2011 | 04:14 AM
GSPOT's Avatar
....you will need a new cat - back system
GSPOT is offline
Old 12-05-2011 | 06:25 AM
High pitch = higher rpm = lean.
HKS exhaust tone means the engine is very rich
beebone is offline
Old 12-05-2011 | 08:19 PM
m33g0's Avatar
Hai so I guess I can't do anything to the pipe already.I searched online but no result..
m33g0 is offline
Old 12-05-2011 | 08:50 PM
valk's Avatar
if you are handy, you could try to make a custom exhaust. resonators ect arent that high tech and im sure you could fab somthing. your engines performance would probably go out the window though as the pipe is a big part of the performance.
valk is offline
Old 12-05-2011 | 09:37 PM
very simple.... put a RC system in your 1/1 car with HKS exhaust and you are done. LOL Just joking.... As RC engines rev much higher than 1/1 it is really hard to get a low pitch tone..... Anything maybe closer are the 1/5 as they only rev to under 20,000 rpm. So the note is much lower compare to .12 or .21 engines.
gpm-parts.com is offline
Old 12-05-2011 | 10:08 PM
Mr Nimrod's Avatar
All you need is a miniature turbocharged four stroke engine.......
Or maybe try a piece of straight thru pipe as it can be difficult to replicate the 'wet fart' sound of a HKS exhaust system.....
Mr Nimrod is offline
Old 12-05-2011 | 10:24 PM
Adding a standard noise silencer can already lower the pitch quite a bit.
Yoshimon is offline
Old 12-05-2011 | 10:29 PM
asw7576's Avatar
Use quiter pipe = change to smaller diameter stinger ( exhaust tip ), I think 5.2mm diameter tip. Expect longer run time and slightly less power.
Use carburator's air box.
asw7576 is offline
Old 12-07-2011 | 04:24 PM
m33g0's Avatar
Thank u guys I will search all possible way that u guys mentioned..
m33g0 is offline
