-   Nitro On-Road (https://www.rctech.net/forum/nitro-road-3/)
-   -   exhaust sound (https://www.rctech.net/forum/nitro-road/574012-exhaust-sound.html)
m33g0 12-02-2011 05:21 PM
exhaust sound
How to make the exhaust sounds like those hks exhaust with deep bass rather than the high pitch sounds?thanks bros !
Roelof 12-03-2011 03:37 AM
Bigger volume
m33g0 12-03-2011 06:52 AM
Sorry i don't understand.
asw7576 12-05-2011 01:05 AM
Impossible :lol:
m33g0 12-05-2011 02:32 AM
Originally Posted by asw7576 (Post 9996848)
Impossible :lol:
thanks if cant make it sounds deeper..how about making it more quiet as i dont wish to disturb other people knowing that i might as well get a ep car but i like still perfer the smell and smoke !:sweat:
GSPOT 12-05-2011 04:14 AM
....you will need a new cat - back system:tire::tire::tire::ha:
beebone 12-05-2011 06:25 AM
High pitch = higher rpm = lean.
HKS exhaust tone means the engine is very rich
m33g0 12-05-2011 08:19 PM
Hai so I guess I can't do anything to the pipe already.I searched online but no result..
valk 12-05-2011 08:50 PM
if you are handy, you could try to make a custom exhaust. resonators ect arent that high tech and im sure you could fab somthing. your engines performance would probably go out the window though as the pipe is a big part of the performance.
gpm-parts.com 12-05-2011 09:37 PM
very simple.... put a RC system in your 1/1 car with HKS exhaust and you are done. LOL Just joking.... As RC engines rev much higher than 1/1 it is really hard to get a low pitch tone..... Anything maybe closer are the 1/5 as they only rev to under 20,000 rpm. :eek: So the note is much lower compare to .12 or .21 engines.
Mr Nimrod 12-05-2011 10:08 PM
All you need is a miniature turbocharged four stroke engine.......
Or maybe try a piece of straight thru pipe as it can be difficult to replicate the 'wet fart' sound of a HKS exhaust system.....:ha::lol:
Yoshimon 12-05-2011 10:24 PM
Adding a standard noise silencer can already lower the pitch quite a bit.
asw7576 12-05-2011 10:29 PM
Use quiter pipe = change to smaller diameter stinger ( exhaust tip ), I think 5.2mm diameter tip. Expect longer run time and slightly less power.
Use carburator's air box.
m33g0 12-07-2011 04:24 PM
Thank u guys I will search all possible way that u guys mentioned..
