Official xxx-nt sport 2 thread
.....Just purchased a new losi xxx-nt does anyone still own one? just thought this thread might be needed just incase.. tips and pointers are gladly appreciated!
maybe he wanted this thread specific for version 2? exactly what is different between version 1 and version 2? I remember when version 1 was getting cleared out had great deals on them, like 230 shipped.
Chrome wheels, Fury body, rear-exhaust Mach .15, and the updated "i" JR radio system.
I always recommend using threads that have already been started, because there are usually posts with information already in them. That's all.
I done the advanced search and couldnt find the thread thats all so I figured there wasnt one? Any way goning to fire up my 6th tank shortly ! Let you know if there are any delimmas! Im not sure if the motors are the same as the old xxx nt . It had the MACH15 mine hasa the MACH15RE ?
So not sure! If its OK with you all can this thread remain cause no one using the old one!
Well cool RE stands for rear exhaust
Finished my 6th tank I think my HSN is right on but done a few WOT passes and checked temp and was 240 F ..Not bad!! so I richened it up on the LSN 1/8 and temps dropped to 220 to 230 ... Still a little sluggish off the line though.. I wish I new actually how many turns CCW I have it on but Ive been playing by Temp, feel, and ear! still emiting fuel out exhaust which is probably good thing any more pointers? 7th tank can I start fine tuning the LSN now?
When tuned aggressively, the engine might run a bit hot, in the 240-260 range (or hotter, but I'm not going to recommend it, haha). While not great, it shouldn't really hurt the engine as long as it's not so lean that it starves for fuel.
The engine will change tune as it breaks in. Make sure you keep the air filter clean and oiled too.
You can check your needle settings. Count the turns it takes to tighten the screw down (don't crank on it) and then back the needle off the same amount. Then you'll know where your needles are set.
If you feel like the engine isn't running right, or that you may have made a mistake, re-set your needles back to their original settings and start over.
It was running around 240 or so maybe tiny bit hotter but Im going on my 8th tank .Is that nothing to be bothered by?....almost finished a quart of fuel. It was spitting at WOT, but from punch through mid range WOWs me how can I get that top end sputter or power drain shook out?
