Old 03-05-2007, 12:01 AM   #151
FrankBlack's Avatar
I reakon them proline gladiator 2's look like they would last. Or them mashers, they look pretty wild
FrankBlack is offline   Reply With Quote
Old 03-05-2007, 02:16 AM   #152
Aaron Waldron's Avatar
Those tires should be good. Also, look at Losi's Smasher tires, part number A-7680R. Losi's foam inserts and rubber compounds are usually good for long life and good grip.
Aaron Waldron - LiveRC
www.liverc.com
Aaron Waldron is offline   Reply With Quote
Old 03-05-2007, 05:51 AM   #153
Thanks a ton guys!
J30Guy612 is offline   Reply With Quote
Old 03-05-2007, 12:31 PM   #154
LOWGEARED's Avatar
Are those the same size as the normal tires for them!!!! I dont really want them any bigger!!!!
Unless
I could be the first XXX MT!!!
MEGA BAJA HOP UP LIST:
GPM BLUE ALUMINUM THREADED SHOCKS
LOSI YELLOW SPRINGS
GPM BLUE ALUMINUM A-ARM SET U/L
ACNCM ENORMOUS COOLING HEAD
INTEGY SWAY BAR KIT
VANTAGE HX5 TIRES
Micro baja
Micro raminator
ALUMINUM PIVOT BLOCKS
FULLY ADJUSTABLE C/C/S
LOWGEARED is offline   Reply With Quote
Old 03-05-2007, 12:36 PM   #155
They are 2.2 tires, and not really much taller than a step pin or other big 1/10th scale tire. It won't change the truck from stock stadium truck to Stampede height, that's for sure.
www.liverc.com
Old 03-05-2007, 12:41 PM   #156
LOWGEARED's Avatar
NO!!! Im not that would ruin the whole LOSI XXX NT IMAGE!!
I got a pair of fronts (silver) and they were premounted on the yellow dish wheels !! Of course they dont match the rear chrome dish!!!
But they seem to be quite smaller than the factory tires.. Has anyone ever noticed this???
LOSI YELLOW SPRINGS
INTEGY SWAY BAR KIT
VANTAGE HX5 TIRES
Micro baja
Micro raminator
Old 03-05-2007, 12:44 PM   #157
What tires did you get? I think I remember the RTR tires being kinda tall.
Like I said, the tires I linked a picture to aren't really any bigger. Probably no bigger than the tires that came with your truck.
www.liverc.com
Old 03-05-2007, 12:54 PM   #158
LOWGEARED's Avatar
These !!!
http://www.losipartshouse.com/servle...ruck-FR/Detail
The factorys are taller,,, not wider!!!!
LOSI YELLOW SPRINGS
INTEGY SWAY BAR KIT
VANTAGE HX5 TIRES
Micro baja
Micro raminator
Old 03-05-2007, 12:59 PM   #159
Is that bad?
www.liverc.com
Old 03-05-2007, 01:10 PM   #160
LOWGEARED's Avatar
Youre the professional here!!!
I dont guess it is other then,, It just looks
to the human eye..
I just wasnt expecting the tires to have a differance in height.. through me off a little!
LOSI YELLOW SPRINGS
INTEGY SWAY BAR KIT
VANTAGE HX5 TIRES
Micro baja
Micro raminator
Old 03-05-2007, 01:16 PM   #161
It won't change anything too much for you to worry about it. Just drive your truck and have fun!
www.liverc.com
Old 03-05-2007, 01:22 PM   #162
LOWGEARED's Avatar
Tanx ALOTTTTT!!
LOSI YELLOW SPRINGS
INTEGY SWAY BAR KIT
VANTAGE HX5 TIRES
Micro baja
Micro raminator
Old 03-06-2007, 11:03 PM   #163
jbmccoy205's Avatar
Trader Rating: 47 (100%+)
Anyone?
So my truck is running perfect until i think the correct word is crank shaft works its way lose and causing the truck slip bad then stalls. I see that the shaft has come lose so I take the pinion gear and clutch out....Ect.... and screw the end back on with lock tight....now it does nothing but slip wont move one inch just revs then stalls...Checked the clutch switched it out same thing......my starter box won't turn over the motor now...........what gives anyone............Thanks
jbmccoy205 is offline   Reply With Quote
Old 03-06-2007, 11:46 PM   #164
rezenclowd3's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to rezenclowd3
I say take it to your LHS and have them look at it or have a friend look at it. Your clutch nut may have come loose or quite a few other possibilities.
OOMSGFX.COM (no longer painting, but take a look for fun!), Roadrunners RC Club
"Racing drivers have balls, unfortunately, none of them are crystal" (David Coulthard)
"I believe the average IQ of a NASCAR fan is only marginally above the things that hit the windscreen during the race. "
rezenclowd3 is offline   Reply With Quote
Old 03-07-2007, 12:08 AM   #165
LOWGEARED's Avatar
Ya thats what I would do too!!! Just to many problems associated with those sYmptoms !!!! Could the diff nut have any thing to do with it though!!
That would be my first guess!!!
LOSI YELLOW SPRINGS
INTEGY SWAY BAR KIT
VANTAGE HX5 TIRES
Micro baja
Micro raminator
** The Official HOT or NOT Thread *** JVT MTX3 Chat Lounge 2431 12-30-2007 05:19 PM
the official r/c picture thread aftershock Chat Lounge 3 11-29-2007 12:58 PM
Official MT2 RTR Thread PowayLAX1 Electric Off-Road 18 03-20-2007 02:03 PM
LST Official Thread Whipple81 Monster Trucks 0 10-06-2004 11:30 AM
The Official xxx-nt thread rushdude Electric Off-Road 1 09-24-2003 04:09 PM
