question about battery
Hello
I have a question I think you guys can help me.
What is the difference when using these batteries?
I found these. if I connect in parallel, can have 10000mAh 2s?
Because that everyone does not use this type of battery? the same price of the other larger.
That sure appears to be a saddle pack. Most commonly used on 4wd 1/10 scale buggies, it's essentially a regular pack in 2 parts for more chassis layout flexibility. If so the labeling is somewhat confusing, they are a 2S 5000mAh connected together. So no to the 2S 10000mAh, in parallel they would be a 1S 10000mAh though.
Note the included harness is best used only for charging. Use solid style bullets, not the spinning birdcage style banana plugs, on the car side for running.
That pack isn't a saddle pack, it's a 1S pack for a pan car. Note the lengths are different, and is sold separately, not in a pair.
Understand the labeling on sadlle packs can be somewhat confusing.
