ESC matches motor?
ESC matches motor?
I'm getting a Losi XXX-SCT 2wd roller and Tekin ESC and Tekin motor. To run stock class, I'll use a Tekin TT2151, which is their brushless Redline System ESC +17.5 turn motor.
If later I change to a Tekin 13.5, 10.5, etc turn motor, can I use the same ESC? Or is the ESC and motor matched to each other? Could I use another maker's motor? Get the same results?
TakeAim
TakeAim
Yeah motor and esc dont gotta be matched. My bud is running a castle mamba max pro and a tekin pro4 4000kv all day no issues. You just dont want to buy a esc rated at 60amps and go and use an 1/8th mamba monster motor lol. That just an example. Just make sure your esc can handle the amoints of amps ur motor draws. Also if your drawing 100+ amps on your setups, get some GOOD batteries. Dont go cheap on gens ace 30c lol
