question about o-rings
hey guys i was tring to lower the ride height of my tt-01. I removed the o-ring from the shocks so that its about 2mm lower...is removing those o-rings going to pose a problem ?
like will the shocks give way when i'm running it ?
I'm not sure where you removed the o-rings from exactly but generally if your removing something from the initial assembly it's probably not a good thing.
You would want to add o-rings anyway if you were trying to shorten the shocks , and not remove them. You can drop the ride by shortening the shocks by adding o-rings to the shaft before inserting it into the body. Just make sure you have enough suspension travel though.
