Need Help with starting up my engine!
Hello!
Recently I just purchased a O.S. 12TZ (P)-T 3-Port Turbo. I am new to gp cars so I am not sure if I did something wrong or if there is something wrong with the engine. The situation is like this. I tried to start up my engine with a OFNA starter box(I have the flywheel aligned to the starter wheel and everything of the starter box setup). However, my flywheel doesn't turn with the starter wheel when they contact each other. It seem like they are stuck against each other. I am not sure of what went wrong. The gp car that I have is a Kyosho V-One RRR EVO. Please assist me ASAP.
Thank You
Thank You
since its a brand new motor you will need to heat up the eninge to about 100-130f with a heat gun befor you can turn it over because of the compretion. also make sure your starter wheel and opning on the chassis is alinded right. you also may need lower motor mounts because the motor mounds are made for a pull start engine. so it is higher up and may not make contact with the flywheel. also check ur battrie packs to make sure they are charged up.and if you are using stick pack go out and get a 12v gel cell.
