TA04-R with Tamiya Stock Type RR motor. what pinion?
What gear is appropriate for my setup? They say the 45t pinion that comes with the kit is too high.
Someone suggested about 38t... what's your opinion?
whats internal ratio?
spur size??
Re: TA04-R with Tamiya Stock Type RR motor. what pinion?
depending on what motor u are using...
it can vary for 5 odd to 9 odd
for stock motor you could gear pretty low..
around 5 odd to 6 odd is pretty common for stock
i geared my 04r at 120 spur with 45 pinion running Type T stock motor.
after dumping 1 3300mah batt pack,the temp is still ok.
my friend tried at 112/45,but the motor is terrible hot after running...
