Go Back  R/C Tech Forums > General Forums > Rookie Zone
How to remove part stuck with thread lock >
Like Tree4Likes
  • 1 Post By the rc guy
  • 2 Post By chuck_thehammer
  • 1 Post By Sir 51D3WAYS
Old 02-19-2019 | 11:39 PM
Default How to remove part stuck with thread lock
Having an issue removing front axles from my B6. I am able to remove the screw holding the axle in but the axle will not release from the bearings. Trying to do this without damaging the hub. Please advise
FDDA15 is offline
Old 02-20-2019 | 12:57 AM
Sometimes they pop out easy and sometimes you have to stick an allen driver inside the hub and hit it on something to get it out. I know it doesn’t sound healthy but you should be fine. A couple hits on a table and it usually pops right out.
richard0714 is offline
Old 02-20-2019 | 12:59 AM
the rc guy's Avatar
solder iron..
1/8 IC Fan likes this.
the rc guy is offline
Old 02-20-2019 | 02:23 AM
a little heat... thread - lock releases at 250 degrees (F)... look it up.. you do not need to believe me.
boiling water....( 212* ) but will soften it..
propane cigarette lighter... many ways..
plastic melts at 325.. so do not over due it...
chuck_thehammer is offline
Old 02-22-2019 | 12:33 PM
Sir 51D3WAYS's Avatar
Heat. Preferably with a cigarette lighter with a small flame so you can control the position precisely.
chuck_thehammer likes this.
Sir 51D3WAYS is offline
Old 02-27-2019 | 07:30 PM
Heat works
Denver_Larry is offline
Old 03-03-2019 | 09:00 PM
R/C Tech Elite Member
Heat will work like others have said but don't overdo it or you'll melt the plastic (assuming it's plastic)
TerpsyTurvy is offline
Old 03-05-2019 | 08:44 AM
Will brake cleaner work? If it needs heat, how about put it in an oven at 250 so it can all be done at once?
johnzhou2476 is offline
Old 03-05-2019 | 09:17 AM
JC3's Avatar
JC3
If the part is stuck due to threadlock on it, then acetone will help. Little bit at a time and let it stand for a few minutes to dissolve the threadlock. Use caution around the plastic parts since I'm not sure how it will affect the plastics on your car. I've used this technique many times on my VBC and AE chassis parts. I also soak screws, setscrews, nuts, and washers in acetone to remove threadlocker. Works great! Let us know how you make out.
JC3 is offline
