Sensored vs Sensorless
Hello,
What is the main difference between sensored and sensorless motors?
Is one better than the other for either racing or bashing?
Are there tradeoffs between them, advantages and disadvantages?
Thx
Thx
A brushless system reads the position of the rotor so the control (ESC) can optimise itself not to outperform the reaction speed of the rotor.
With sensorless it is done by reading the generated voltage in the coils of the motor when a magnetic pole floats along a coil like any dynamo works. The amplitude of the generated voltage is determining the speed the magnetic pole floats by. At zero RPM the esc will not read a thing as also with very low rotations. At a certain RPM level the ESC can read the feedback pulses and will work optimised with the motor, below that the ESC is a bit guessing resulting in what we call cogging.
Sensored is using electronic sensors to detect the position of the rotor. These sensors work all the time over the whole rpm range giving a much smoother control, even from when the car is standing still.
A racer wants to have the perfect start and control to get the best performance. A basher does not mind using sensorless because he wants to go full throttle and does not even notice the tiny struggling to start up.
Less parts than can go wrong, so yes, in theory it's a bit more reliable. But over all it's more about what you do with your car. If you plan on bashing it on an open area, sensorless is enough, as you'll spend very little time (or attention on) going slow. If you plan on racing (or just driving on a track) sensored makes more sense, as you need a smooth running car even in the slowest corner.
Trust me, even if you're just bashing around a lot, a sensorless motor can be very glitchy when you're on and off the throttle or at low speeds. When your car is not running smooth, it can kill the fun.
A tiny flimsy connector getting thrown around in dirt and/or water is a point of failure waiting to happen. So reliability is definitely worse. If you race seriously I guess the smoothness is worth it. I do race but it's more of a backyard (abandoned quarry) SCT league where the trucks get a serious beating and an occasional puddle crossing. 🤷
Answering general questions based on quarry basher league experience might seem helpful but if someone was asking this question to go check out a local track then your advice just cost them money. Sure for submerging your stuff in a mud puddle go cheap sensorless......any real driving it's sensored or it's worthless.
but i get it, if you're just goofing around with friends and the competition isn't overly serious, why bother as long as everyone is having fun.
Are there tradeoffs between them, advantages and disadvantages?", so... Sensorless is just fine for bashing. Depends on the system, of course, some are smooth, some are crap.
I'll get back to my non real driving now. 🤪
Sensorless is also good for racing if you want to get rid of cheaters who like to cheat with sensor timings. Also the need for rotor shimming will be less. But because the cogging issue and the option for cheating no racer wants to run sensorless. And yet, there are pretty decent sensorless ESC's to find with a decent control. I also bet if sensorless can become a new stock racing ESC's will get a better development to be race worthy.
11Likes
