Battery Help
Battery Help
OK I got a lipo 2200mi 30c 11.1volt. My ESC is a 50amp. My motor is a Turnigy SK3 brushless. The volt rating on the motor is a max of 11v. Will the motor be ok with running the 11.1v Lipo?
Yes no problem, your battery volt rating and motor volt limit matching. Make sure the motor max Amp (A) requirement match the ESC #A rating. I do own SK3 brushless motor.. it should be ok for normal flying on 50A Esc.
The ESC is what you should be concerned about - that is voltage dependent. A motor will handle any voltage as long as it is propped appropriately - too large a pitch/diameter/#ofblades and you will pull too much current which will burn it out.
