Prop???
Prop???
I just bought a 37 inch AC models wave slave, it has a go .21 engine and it needs a prop. I have gotten a couple recommendations, one of which is a 40x 52x3 aquacraft and the other is a 40x53x2 aquacraft. My friend had a 3 blade on his blackjack 55 & it had a little more top end but it cavitated real bad. Will any 3 blade cause more cavitation? Or maybe his prop wasn't sharpened & balanced properly. (not likely cause he's a perfectionist) I'm not racing so I'd rather have the low end drivability & sacrifice a couple mph. Any info is greatly appreciated!
Hi,
I do not run gas at this time.
But I do run a lot of FE mono's and do like using three blades for for them,
They help the boat run smoother and with less torque roll to.
I am not sure on the HP you have there with that motor,
But it would help if I could see how the boat runs with the s&b prop that you are running now,
And also what temps the motor is running at.
Than maybe I could help you find a good prop for that setup,
That will not over heat the motor and burn it up.
I am always on this OSE forums if you need any help,
Just look for Lenny hear. http://forums.offshoreelectrics.com/forum.php
OSE won't do you any good as they don't like fuel burners very much. The problem is finding a prop that the boat likes. Yours isn't any everyday combination so it might take a few props unfortunately to find the right one. It might need someting as small as a 37mm or as big as a 42mm prop. A 40mm prop like the AquaCraft GrimRacer choices, an Octura X-or M-440 will put you in the ballpark. It might like a Prather 215 or 220.
Comparitively the Grimmie props are good buys as they're well-balanced and fairly sharp out of the package, they're decently sharpened but not cut the censored out of your fingers sharp.
With my old Speedmaster 21 with a Rossi (not Nova Rossi) in it I went through a lot of props trying to find one that the boat liked. As the engine broke in it wanted more prop. The dealer that I bought that motor from wanted my feedback on it as I was the first one to get one from him. My boat ended up by loving an Octura M-445. He didn't believe that it could spin a prop that large as it's made more for .45 engines.
I actually haven't even ran it yet. I'm just looking for a good starting point. It's going to be awhile before I can run it, the boat is torn apart right now and at the paint shop. Also, I am confined to an electric wheelchair and I'm waiting for repairs to be made to my wheelchair. What would you recommend for a starting point?
Octura X-440 or the AquaCraft 40x53 then.
I have a Proboat 36"shockwave that I modded to FE and I am running X646/3,
And getting about 45 mph on gps.
http://www.youtube.com/watch?feature...&v=ufp1qtvQias
I guess a x442 would be a good starting point,
It kind of a all around prop for that size of a hull.
Hear is a cheap way to test to find what props are going to run best for the setup.
http://www.offshoreelectrics.com/pro...led+Propellers
http://www.offshoreelectrics.com/cat...led+Propellers
Also like I said there are lots of guys that run both Gas & FE boats,
So you may find more help than you would think on OSE site.
Hears Just one post I have found by a search on yahoo for a prop for your boat,
But you can try a search on OSE site as well.
Or just put a post up for some info on your boat.
http://forums.offshoreelectrics.com/...-needed-please
61, you're comparing apples to oranges here. With a nitro powered Shockwave we found an Octura M-445 to be a very good prop for that. Making it electric changes the game.
I run gas and nitro boats. I've done business with Steve a few times. I have been converting electric hulls over to nitro power, and have posted pictures of my builds there and the members just didn't seem to be interested.
prop help
This website has a wealth of information for boating nitro or electric . good luck
http://www.radiocontrolinfo.com/NitroBoat/propeller.php
Suspended
