Futaba 4PLS model select >
Like Tree1Likes
  • 1 Post By anthonyscardina
Old 09-10-2017 | 03:36 AM
Default Futaba 4PLS model select
Good morning,
Was wondering if the 4PLS has a shortcut button for model select?
Thank you in advance
Rcracing01 is offline
Old 09-10-2017 | 05:17 AM
Roelof's Avatar
Manual?
Roelof is offline
Old 09-11-2017 | 03:21 PM
dnsducks's Avatar
Not sure if there is a shortcut. But you just have to go to the menu and go to the model then select plus minus to and main button to execute.. Its on menu over and a couple of button pushes. pretty easy
dnsducks is offline
Old 09-12-2017 | 03:02 AM
I change models on mine half a dozen times a day, it's the quickest menu I've used yet. You can hit up to go from top of menu straight to the bottom, if that helps.
Daking16 likes this.
anthonyscardina is offline
