RX 482 Telemetry
Just upgraded to the RX 482 from the RX 462. When I was using the 462 there was a lead to connect to the positive battery lead to read voltage from my M12S. Now with the 482 there is a slot for battery with a signal, positive, and negative pin. Which pin do I connect to the battery to read voltage? There is no info out there that explains how to this with out using their esc.
There are "make offer" Asian sellers on ebay that you can get great deals and service from.
The manuals can be hard to read unless you know Japanese, tho...
With the 482 to read accurate motor battery voltage, you need a sanwa ssl esc. Otherwise it will show receiver voltage. The 472 and 482 are internal telemetry without external sensors or soldered leads. In order to get full telemetry you have to pair the 47/82 with sanwa esc. This is common for any system that supports full telemetry. I can tell you that the sanwa telemetry system is the tits. You can get massive discounts buying from asia, but no support stateside. It's a risk that I take...
