Loss in performance
Hi guys, i want to share my experience and i’m looking for any suggestions. I have a TLR 8ight with a 4268 motor and a 180amp esc. I am doing speedruns at the moment so i use a 20t pinion with a 45t spur gear. The problem is that i experience performance loss after the first five minutes of a couple of sprints and general mild driving. Maximum temps i see is 150f on the esc and 130f on the motor. The battery i use is a Gens Ace 4s 6750 70c which gets warm but not hot and only has about 15 charge cycles. Any ideas with what’s causing the loss in performance? I have tested the battery and all cells were at 3.79v after 10 minutes of driving which means that a big voltage drop is unlikely. Also, all cells have IR below 5.
In other words, for what you are doing, actually, nothing seems unusual even if you are only doing a limited number of full pulls in that time.
I can speak to my on-road cars, -after 5 or 6 mins performance does start to fade, ...its not super noticeable but I can see it w/ my lap times. I am usually going all out for 5 mins (qualifying) and 6mins in mains. My experience is both motor gets tired and battery starts to lose its punch. I believe that is normal. ..especially if your doing all out speed runs ...5 mins or so and you'd expect to see some fade.
