Tekin Hotwire 3.0 Bluetooth Thread
#136
Thanks for your reply Randy.
on Datalogs, my RPM data is showing as 3846rpm at rest. Is it safe to assume I just deduct that figure to get the true rpm. Is there a calibration for datalogging? TIA.
edit. Both ESC’s 2wd & 4wd buggy RS Pro BE are showing 3846rpm at rest. With this in regards to setting timing with RPM ranges. Should we take this 3846rpm into account?
#140
Is there anyone with an iPhone and Hotwire 3.0 that can test the following?
Set the punch control to 10 (max) and verify on the ESC or hotwire on PC if the punch level is really at the max. When I set level 10 on my iPhone, it is only level 2 on PC. I have to set level 8 on my iPhone to get the max punch. And level 1 in hotwire on Iphone, is level 3 on PC.
#142
#144
Hi to everyone,
I too have some of the above troubles. I use an RSX and some RSX Pro. I have the same troubles with a clean Windows 10 N install on an laptop where Hotwire worked without troubles on Windows 7. I am quite sure that the problem with windows is connected to a library that may be on most machines, but not on all. Maybe Chris could post a checklist or even better a checktool which could list all important softwarecomponents on TEKIN User PCs. Like the directXdiagtool - this could speed up troubleshooting - if the problems are not exactly sorted out yet?.
I got in touch with TEKIN (Randy,..) cause my hotwire 3.0 did not liked the update either. I also reported some screenshots. I hope Randy will respond soon as it is a pain do not be able to load/save settings.
My Hotwire 3.0 connects and binds troubleless to Android and iphone (5s) - Android just fails after reading the ESC settings.
iOS is at least so kind posting why: ESC firmware is unknown to ... download latest app - and than quits.
For those who use windows with the screentroubles (missing filename field) I have a workaround - a very dirty one: Hotwire does install some default settings. I was able to use the right mouse menu to copy those whithin the dialogbox, rename them and save over them.
Not a usabilty master, but at least it works.
Sorry for my english, hope the things mentioned make sense to you.
Randy I would love to see a Hotwire 16.00 with the same GUI as the ServoGUI or all the features pumped into the Android app ;-)
Can anyone confirm a working bluetooth setup between an RSX pro and Hotwire 3.0? Mine just work via cable |-(((
Love my new RSX Pro's !!!
#145
Hi,
i am a long time TEKIN racer and just swaped from my RSX and RS to the new RSX Pro. I really love the RSX Pro, but I sadly can confirm too to have troubles.
1. connecting a brand new Hotwire 3.0 via bluetooth stops on Android and iOS after reading the ESC settings (iOS is so kind to give a comment that the firmware is unknown and I should update my Hotwire)
Had no luck to upgrade viad cellphone yet, windows does not offer any upgrade (did it on older versions!)
2. I have visual troubles to set a filename in the Hotwire Software under Windows 10 on my Pit-Laptop (tried about 6 PCs Win10, some work, some have this behaviour)
Perhaps Chris could build us a "Tool" to check the PCs whats on them like directXdiag.
I am quite sure there is a library missing or any kind of driver is expected (which is not default .net 35
My PitLaptop worked great with Windows 7 - had to upgrade.
Gladly Hotwire 1 and 3 (don't have a 2.0) work without troubles via cable on Windows.
Would be great to hear some news from Randy
best regards
Antonio
PS.: I am no Apple User - what cable would I need to use my testing 5s to connect it to the Hotwire? (Do I need an OTG cable like on Android?)
best regards
Antonio
#146
Hi,
best regards
Antonio
best regards
Antonio
Always use a PC to update your PC and Hotwire if/when prompted. You cannot use a cable with ANY iOS mobile product with a Hotwire. We spoke to Apple years ago, and were flat out told no. Hence the BlueTooth Hotwire.
The Hotwire should work just fine using a windows based PC. IF you're having issues, send me the info and I'll help sort out your issue(s).
#147
I was excited to see an update for the app on my iPhone. However, there are bugs in program which makes it useless. The torque level continuously goes back to 10 and when I try to change it throttle frequency changes to 12k. The brake frequency is changing on its own as well. Need to fix the bugs before release, because it is unusable at this time.
#148
It looks like someone submitted the app without testing it first...
#149
Please email us at [email protected] so we can figure this out.
What esc are you using it with?
What software version is in the esc?
What is the version number of the IOS app that is installed?
What Phone are you using?
21Likes
