Headsets, suggestions and ROAR Rules >
Like Tree20Likes
Old 05-08-2019, 06:55 AM
  #46
Jomo918's Avatar
Im considering trying a over the ear headset designed for XBOX or PS4 since it has the 3.5mm jack and is designed for 2 way communication. I found really good brand ones on ebay for no more then 20 dollars a headset. Plug it into the cell phone and call your buddy in the pits. I really think it will work well but just haven't bought the headsets yet. If i do ill update this thread of how it works out
Jomo918 is offline
Old 05-08-2019, 07:39 AM
  #47
Originally Posted by iplaygames View Post
a google search has thousands of results for bluetooth communication, in-ear and over the top etc.
token is offline
Old 05-08-2019, 11:00 AM
  #48
I was actually thinking about testing that route as well.
KeeneRc is offline
Old 05-08-2019, 12:50 PM
  #49
Suspended
There you go. We use a bluetooth app with single sided gaming headset... i dont understand why people would ask for a link on this... clearly there is not just one option lol
iplaygames is offline
Old 05-09-2019, 09:23 AM
  #50
Link to what YOU use? You can just ramble on or you could share what you actually use. If you are providing advice, I would assume you have tested and used something. How hard is it to share a link.
Here's what most of the racers use UltraLITE PG1. They are by far the best option. Simple to use and no burden on a pit man. Turn them on and go. They are expensive, but if you race nitro like I do, they are worth every penny.
token is offline
Old 05-09-2019, 01:05 PM
  #51
after i read that post, i had a search and found quite a few ideas that were cheaper. Sena creates way higher quality systems for less.
If you look under motorbike communication you can find really high quality gear for less, theres a good chunk on Ali Express for cheap that work really well too.
MonsterJuice is offline
Old 05-10-2019, 10:19 AM
  #52
If y'all want to be helpful post a freakin link. Otherwise, its garbage that has NOT been used or tested for RC nitro racing. Eartec is still the best. Prove me wrong.
Senas are about $200 EACH..........................
token is offline
Old 05-10-2019, 11:49 AM
  #53
Trader Rating: 25 (100%+)
go a page back and check out what I said, the sena system isn’t better then my set up with the noise canceling headphones and lexin r6 85$ on Amazon and 14$ for the noise canceling headphones from harbor frieght. The sena has a lag so it almost sounds like an echo. My set up does not.
Matt Piva is offline
Old 05-14-2019, 06:19 PM
  #54
Default Lx-r6
Made a pair per matt and they are awesome! The only downside i see is might be a little hot in summer but they work really well for total of $120
raylesk is offline
Old 05-14-2019, 07:36 PM
  #55
FYI - I dont belielve you can use blutooth headsets at ROAR events. Blutooth run on 2.4 and the absolutely can interfere.... just a note.
token is offline
Old 05-14-2019, 10:24 PM
  #56
those look sick. Some stickers and the muffs will look sweet!! They look a lot like mine
Old 05-15-2019, 05:18 AM
  #57
https://www.amazon.com/LEXIN-Motorcycle-Bluetooth-communication-intercomunicador/dp/B01MRO5VM3
and this
https://m.harborfreight.com/ear-muffs-94334.html?utm_referrer=direct%2Fnot%20provided
thanks Matt for sharing!
raylesk is offline
Old 05-15-2019, 01:47 PM
  #58
Better?
raylesk is offline
Old 05-16-2019, 06:46 AM
  #59
RCSureStart's Avatar
The EFRA rule book states that the driver can only have a single ear headset so they can hear the race director so these wouldn’t be suitable at a lot of race meets. (Unless I’m wrong)
RCSureStart is offline
Old 05-16-2019, 07:09 AM
  #60
1/8 IC Fan's Avatar
Trader Rating: 96 (100%+)
Easily Solved, Cut a hole in the opposing ear side, take out the inner foam, leave the cup and cup seal.
1/8 IC Fan is offline
