Mixing Wire Gauge?
Old 05-14-2017 | 12:57 AM
Questions?? Mixing Wire Gauge?
Is it okay to mix wire gauge on my SCT?
I bought the hobbywing XR8 Combo with the 4300 motor. It comes with 12 gauge wire to solder the motor to the esc.
I also have 12 gauge wire that's already got the Deans plug on one end and I was going to solder the free end on to the ESC.
So the question has to do with the batteries. I've been told to go with SMC batteries but they use 10 gauge wire. True Spec Premium 7.4V 7200mAh 131 Amps
Is it going to be an issue that the batter has 10 and once it hits the deans connector everything else goes down to 12?
theishkid is offline
Old 05-14-2017 | 07:13 AM
You are fine with the 12AWG on the electronics.
RC Juice is offline
Old 05-14-2017 | 07:40 AM
EJ2civic's Avatar
As RC Juice said, you are good. I run the same batteries in my SCTE 2.0 on a XR10 Pro mated to a Novak Ballistic 4.5t 550 2 pole motor. The only difference with mine is that I am using 5mm bullets on the ESC.
EJ2civic is offline
Old 05-14-2017 | 10:25 AM
So thanks for the clarification on 12 being okay. But just for clarification is it ok that all electronics are 12 and the battery is 10?
Old 05-14-2017 | 10:27 AM
EJ2civic's Avatar
Yeah...you should be fine...
EJ2civic is offline
Old 05-14-2017 | 10:59 PM
Thanks for your help guys! I pre-ordered a couple of the 2S Lipos. Hopefully they'll be here in a couple of weeks.
Old 05-28-2017 | 12:43 PM
It's always okay to go up in gauge (from 12 to 10), but not always okay to go down in gauge (12 to 14).
For any electronics, find the amperage you will be pulling and use at least that sized wire. Bigger is fine/good.
Ampacity Charts
iliveonnitro is offline
Old 05-28-2017 | 11:37 PM
technically the wire from the batt to the esc "should" be larger than the esc to motor as the current from the batt is DC along 2 wires and the motor wires is pulsed across 3 wires . but lets face it, it makes not much difference
Lunchie is offline
Old 06-01-2017 | 07:25 PM
platgof's Avatar
If the battery has a 10 gauge wire, you should run 10 gauge wire to it from the esc. 12 gauge is fine to the motors from the esc, as it is divided into 3 wires. I have found this to be the best way, and with today's high power batteries, they can get very hot. I had a lot of problems with one high power battery, so I used a 10 gauge wire from the battery to the esc and the heat problem went away. Why take a chance.
platgof is offline
Old 06-02-2017 | 10:39 AM
There is a lot of misinformation in this thread regarding wire sizing and understanding of how electricity works. Some basics:
  • Power consumers create an amp draw or "pull" from a power source.
  • The power source provides voltage or "pressure"
  • As the power is drawn from the power source across wires or another conductor, heat is created and voltage is lost.
  • The resistance between the power source and power consumer determine how much heat will be created and how much voltage is lost by the time the power gets to the consumer.
Now lets examin the OP's question.
First the battery is rated for 7.4 volts (8.4 charged). This is the available voltage or pressure we're working with. The amperage rating listed is the manufacturer's recommended maximum before damage to the battery occurs. It is worth noting, however, that there is nothing preventing a power consumer or failure (think shorting the + and - leads) from pulling more amperage than the battery is rated for. That would be the job of a fuse or circuit breaker which are not built into batteries. As most know, if you were to short the leads it would not take long for the wires and cells to get very hot and will end in a firey death for the battery if it is allowed to stay shorted. This is where the stories of lipo "explosions" come from.
Next we'll look at the wire size. From the basics we know that the resistance between the battery and ESC is our primary concern. One way to reduce the resistance is to use a numerically smaller (thicker) gauge wire. Another way is to shorten the wire. To scientifically say whether the 12 gauge wire will be a limiting factor the OP would need to measure the resistance of the 12 gauge wire vs the same length 10 gauge wire. He could then do the math and determine how much of a difference there is. This is where the garden hose analogy is often used. The water pressure is the voltage, the hose is the conduit, and the sprinkler is the consumer. A shorter or larger hose will provide more water to the sprinkler with the same pressure. This is what we try to do with large short wires as well. On the flip side there is only so much water the sprinkler will use. There is also a limit to how much power (voltage) an ESC can put to use.
To truly know if the 12 gauge wire is sufficient the OP would have to know how much amperage is being pulled by his ESC while it is in use. The amp draw will vary during use with maximum draw on acceleration from a stop or braking and minimum while at top speed or idle. The simple way to check is to simply feel the wires after a run. Are they too hot to touch? You're probably in the danger zone. Are you melting the solder connections? Something needs attention. Are they simply warm or hot? Then you're in the clear. You could probably gain a fraction of a second in your lap times if you stepped up the wire size or shortened the length but for most the gain won't be noticeable.
I looked briefly but could not find any wire size calculators for the short lengths of wire and voltages that we work with in RC land. Most are aimed at home wiring or car audio wiring.
All that said, the simple answer is that the OP will be fine with 12 gauge wire from the deans connector to the ESC. The amount of extra resistance created for the short length of wire will be minimal. Possibly even less so than the resistance in the deans connector itself. Connectors are where most of the resistance is in a battery to ESC connection. In addition, if the 12 gauge wire was provided by hobbywing then they have already determined that 12 gauge is enough to handle the loads that their ESC will typically use. The 10 gauge from the battery would be like taking a fire hose and connecting it to a garden hose before going to your sprinkler. Could you eliminate the garden hose and run the sprinkler directly from the fire hose? Yep but you likely won't get much more water out of it.
jkaetz is offline
