How many amps can you charge at through the balance plug?
I was thinking of making an adapter to charge my batteries through the balance lead but just wondering if those wires are a little too thin.. Would I be able to charge at 5a though these safely?
Really do not understand what do you want to do.
Easy, charging my receiver battery requires a balancer lead and a charging lead. But on the balancing lead are also the poles of the battery so you can make 1 charging lead. I have seen people with 2S receiver packs and a futaba connector where the white wire was connected to the connection in between the 2 cells. In this way they could do a balanced charge of the pack over the power connector.
Bu I have also made a balanced charging cable on the balance connector and charging with 2A was no issue.
Just saw this same question pop up yesterday on another forum:
How many amps can you charge at through the balance plug? - Electric Motors, ESCs, batteries, etc. @ URC Forums
I would check temps on the wires every 30 seconds... if the wires get any warmer than 120° then I would start to cut back the current.... the biggest variable is the length of charge cable you're using... the longer the wiring, the greater the resistance which consequently increases temps.
This charger uses 5amps through the balance lead.
https://www.banggood.com/Charsoon-Ma...p-1124496.html
The JST XH connectors used on most battery balance connections are rated at 3 amps maximum. They accept wire from 22AWG to 30 AWG. 22AWG and 24 AWG wire will handle 3 amps; smaller gauges are rated for less current, with 30AWG good for 0.86 amps.
See what you've got, and set the charge current appropriately.
