Tool to Shorten Servo Leads/Wires
Hansen Hobbies, a little pricey compared to the economy tools out there, but absolute delight to use. Good place to buy your connector stuff, we used to build wiring harnesses for RC airplanes and always ordered from Hansen's.
Watch the video on the their site to see how the tool works.
Deluxe Crimping Tool
side cutters old plug... strip wires... solder new leads heat shrink...
I openthe servo's, desolder the wires from the PCB, shorten them back to the PCB and when closing the servo again I put some kit on all edges to make it water tight.
Untitled Document
Untitled Document
Agree with belewis. Hanson Hobby ratcheting crimper is the best. Ratcheting crimper although expensive its the only investment you'll make. Been using it for 12 years, on my aircraft and cars.
Hanson's best but Amazon has IWISS racheting Crimper for $20. Up to you. Hanson supply the connectors and plugs Airtronics or Futaba and wire if needed. Practice on crimping before you do the project. it can be done less the 30sec.
99% of the time you're shortening the pigtail anyway.
I've done a couple by opening the case and resoldering the wires shorter, some are right on top and some are a major pain
