SMC RF-170
#19
Is there a way to get the wire from the esc to the reciever/ program box, I had a wire break at the little white connector and am unable to repair it
I am ok with just finding the white small connector with wires attached to it as well.
#20
https://www.amainhobbies.com/maclan-...cl4117/p580796
#21
I wonder if that small white connector on the SMC wire is common with the other manufacturers? Take the following for example:
I think so !!! Thanks
#22
Anyone having an issue with the 2s 170 Esc the power light blinks to indicate blink mode. But if I watch it it flickers. It’s not a steady blink.
I had one do this and also noticed that the brakes would lock up while on the car stand if I rotated the tires slowly by hand.
Sent it in and it was replaced.
Got a new one and installed it and noticed that it too is flickering.
I have tried:
2 different Rx
New sensor wire
Different motor
New, never used model set up on the radio
I’ve recalibrated it numerous times
Still flickers.
Anyone else notice this?
I have tried:
2 different Rx
New sensor wire
Different motor
Still flickers.
#23
I have tried:
2 different Rx
New sensor wire
Different motor
Still flickers.
I have tried:
2 different Rx
New sensor wire
Different motor
Still flickers.
#25
I, too, have an EB410 and have it geared 28/81 with about 42 degrees of timing on the end bell of the motor. Temp is about 110 at the end of a heat.
Got a GForce Motor Analyzer for x-mas and will be hooking it up later today.
#26
I am. Not a first rate driver by any means, but I've not had any complaints with this combination. With all motors ya gotta find the right combination of gear and timing for your track and driving style.
Surprised to find I was drawing only around 4.0 amps at 42 degrees. Didn't record KV at 42, but I did get it at 40 and 45 and 50 degrees on the end bell.
Degrees (can) -- Degrees (analyzer) -- KV -- Amp Draw
40 -- 37 -- 3191 -- 3.4
45 -- 41 -- 3368 -- 4.6
50 -- 46 -- 3877 -- 8.8
Huge jump in both KV and Amps from 45 to 50 degrees. 47 degrees put me at 6 amps and 3530 kv. We'll see how that works next time on track.
If anyone has any wisdom on whether or not 6 amps is appropriate for this motor speak up.
#27
This pertains to the issue of no drag brake in forward , but works in reverse.
ABC is hooked up correct. Running sensored only. Works great just no drag brake in forward.
#29
Radio is a Spektrum DX4C.
Receiver is a Spektrum SR410
The ESC SMC RF-170 is in a T5M with 3 gear trans hooked up to a Tekin Gen3 17.5, running sensored with boost and turbo. Runs great except no drag brake in forward. Brakes will lock up at 100%. I run reverse at 50% and drag brake works in reverse.
Calibrated it several times. Tried reversing radio, wouldn't calibrate then.
Any ideas would be appreciated.
3Likes
