Current limiter dosent work in sensored mode? >
Old 02-11-2017 | 04:32 PM
Morpheus847's Avatar
Default Current limiter dosent work in sensored mode?
I have a 120 amp brushless hobbies esc with a trinity duo 10.5. Problem is when the sensor wire is hooked up the current limiter does not work. If i unhook the sensor wire then it works as it should but as expected coggs. Is this just because of the older motor i have or what?
Morpheus847 is offline
Old 02-11-2017 | 05:14 PM
Have you tried a different motor, as it could be a motor issue instead of esc
Troubles Dad is offline
Old 02-11-2017 | 06:39 PM
That's kind of what I was thinking something to do with the motor. Haven't tried another one yet, was just curious if anyone has had this issue before
Old 02-11-2017 | 07:22 PM
First try a different sensor wire if you have one.
Andy Koback is offline
Old 02-12-2017 | 04:46 PM
tried a different sensor wire, nogo
