Maximum temp for rc motor >
Old 08-22-2016 | 04:02 PM
aedan929's Avatar
Questions?? Maximum temp for rc motor
Hi, I have a Dynamite FUZE DYNS1609 in my vaterra Halix the throttle trim on the controller is set decently high for backwards, it is set like this because i tend to crash a lot and it will stop the car without me having to do it manually! But I have noticed a major temp increase, i have a castle fan (on the motor) which is throttle controlled (full throttle = full fan speed, idle = very low speed). is this recommended to have the throttle trim that low? Anyways my main question is what is the max temp for this motor
Thanks in advance!
aedan929 is offline
Old 08-22-2016 | 04:07 PM
aedan929's Avatar
oops the motor is a DYN4833
aedan929 is offline
Old 08-22-2016 | 06:03 PM
Woulvesbaine's Avatar
I don't know those motors specifically, but when it comes to 540 sized brushless motors, I try not to exceed 140 F, though I know others will have their own view.
Woulvesbaine is offline
Old 08-22-2016 | 06:14 PM
Default Turn engine on full
make the fan run constantly at near full if not full. as well as depending on your rc get a hi flo body for it or make holes in existing body
_attiswil_ is offline
Old 08-23-2016 | 06:57 AM
motorfinger's Avatar
I usually go no higher than 100 degrees over ambient temp.
motorfinger is offline
