Modding a Hewlett Packard 750 Watt Power Supply >
Old 08-27-2016, 07:45 PM
  #16
platgof's Avatar
I learned the hard way to never hook up the battery, or the charger, before plugging the power supply in, good by Reaktor 300 charger, ouch. What painful(expensive) lessons we learn.
platgof is offline
Old 08-28-2016, 08:23 PM
  #17
Originally Posted by Socket
Or buy from ebay for $35 shipped with all the work already done
Thats what I did about 7 years ago and it has been flawless. 45amp from Strick. now carbon wrapped - oooohhh. lol
hsp-sandiego is offline
Old 08-30-2016, 05:57 PM
  #18
platgof's Avatar
They are around 62.5 amps now, the HP 750 watt. This is what I now use as I finally got it modded. I also picked up a Junsi 206B charger, what a system. The HP 750 has enough amps for two of these chargers. If I get a parallel board, I could charge two batteries at once with this charger. I plan on charging all my batteries at 1.5c.
platgof is offline
Old 08-31-2016, 06:26 PM
  #19
Stubbs's Avatar
Trader Rating: 58 (100%+)
Originally Posted by platgof
I haven't seen any dual HP power supplies in that price range with the work already done, no way. I want to see your cards on this! Stubbs, where did you get the heat shrink tubing, and did you isolate the one unit's ground? and how? I also want to know how you hooked up the power from one unit to the other? in series?
Sorry, I haven't been on the forum very much over the past couple of weeks, and didn't see your questions.
- What heat shrink tubing are you referring to?
- You isolate the ground on one unit by drilling out the metal nuts that the PCB is screwed into, and replacing them with plastic ones. This makes that particular PS a "floating ground". The RChelination article goes over that in detail.
- Yes, hook them up in series.....negative from PS1 goes to positive of PS2. If you put extra bullets on each unit, you can connect up a set of 12V wires, as well as a set of 24V.
Still waiting for my resistors from China. Maybe this year! Socket is right, single power supplies around $40, ready to go.
Why did you buy resistors from China? I went to my local Radio Shack, and picked up a 5 pack for $1.49......
Stubbs is offline
Old 09-03-2016, 07:07 PM
  #20
platgof's Avatar
Radio shack went out of business in this area a long time ago. The shrink wrap is used to wrap two power supplies together.
platgof is offline
Old 09-03-2016, 08:52 PM
  #21
spu83's Avatar
Check the AC power input ground is isolated too.
spu83 is offline
Old 09-05-2016, 06:32 PM
  #22
platgof's Avatar
Thanks. I am still debating whether I really need such a powerhouse just yet. The HP 750 by itself is no light weight. I just find it so hard to believe how cheap these are. Does anyone have a source for the dual plugs to run two of them?
platgof is offline
Old 09-05-2016, 07:50 PM
  #23
Stubbs's Avatar
Do you mean the power cord from the wall outlet?
I found this one on newegg.com and Amazon, but you can just google "computer power y-cable"
http://www.newegg.com/Product/Produc...82E16812200045
https://www.amazon.com/StarTech-com-.../dp/B0002GRQR2
Stubbs is offline
Old 09-08-2016, 05:31 PM
  #24
platgof's Avatar
Yeah, the second one is it. Thanks! That will make a duo easier to plug in.
platgof is offline
Old 10-14-2016, 08:37 PM
  #25
Phelps's Avatar
Trader Rating: 18 (100%+)
Does anyone know how or if I can put a usb charging port on this power supply?
Phelps is offline
Old 10-15-2016, 01:21 PM
  #26
platgof's Avatar
The power supply usually doesn't have one, it will be on the charger, as my Junsi 206B has one. I now run two chargers off this power supply, the HK Reaktor 250 watt @ 10 amps, and the Junsi 206B @ 20 amps. They both work excellent, and are highly recommended. I spent $25 on the power supply, and $165 on the chargers, what a bargain. I use the Reaktor on 2s, and the Junsi on 3 and 4s batteries. I charge 2s@ 9 amps, and 3/4s @ 12 amps. Batteries are ready very quickly.
platgof is offline
Old 10-16-2016, 08:33 AM
  #27
Trader Rating: 16 (100%+)
Please elaborate. I've hooked up my Reaktor 300 charger to the power supply before plugging it in and have never hurt it. (I have a modified server power supply) However, I do not have a battery hooked up to the charger at the time. Why will this hurt the charger?
glennhl is offline
Old 10-16-2016, 11:50 AM
  #28
platgof's Avatar
There is a warning to never have the battery hooked up before turning on the power supply. If you look at their ad for the charger it is at the bottom. I heard that some power supplies like the modded computer types spike when plugged in. I never had this problem with the other power supply I use,the HP 600 DPS. The DPS is a better power supply, but rather large, and the HP 750 is amazingly small for the power it has.
platgof is offline
Old 10-16-2016, 12:25 PM
  #29
Roelof's Avatar
Go to a local wallmart, get a 12v car sigaret USB charger. Tear it appart and make it fit
Roelof is offline
Old 10-17-2016, 12:43 PM
  #30
I've been doing this for years. I just cannibalize them from old servers so it's all free for me. The only thing I haven't figured out is how to run them in series. Everyone keeps talking about removing the ground from PS2 but never actually explains how to do it. Someone said to isolate the PCB on nylon nuts but that doesn't make any sense because you are using metal screws that will still ground. Others have said to disconnect the A/C ground but again, doesn't make any sense because in older houses the ground and neutral wires are tied together at the circuit breaker.
LVNeptune is offline
