Icharger 406 vs 4010 >
Old 06-26-2016 | 12:41 PM
JAE
Default Icharger 406 vs 4010
I may upgrade to this since I need a duo. For 17.5 stock racing, are there any practical differences between the two? Thx in advance! May sell my reaktor 30amp charger (rebranded Icharger 3010b) which has been an awesome charger for one of these but don't know if I can justify the prices...
JAE is offline
Old 06-26-2016 | 12:44 PM
DirkW's Avatar
Take the 406, unless you need more than 6S.
DirkW is offline
Old 06-27-2016 | 07:36 AM
Dan's Avatar
Dan
406 is also a heck of a lot smaller too. Saves space in the pits.
Dan is offline
Old 06-27-2016 | 11:27 AM
JAE
I ended up getting a 4010, as it was $290 new, and figured it would have better resale value. While I'm here, anything notable that one needs to know about 1st steps. IE: don't plug in certain way it will blow up, etc.?
JAE is offline
Old 06-27-2016 | 03:25 PM
Suspended
Make sure your power supply is completely wrapped and separate from the charger. If your charge cables touch the P/S while plugged into the charge, it'll smoke a channel.
Make sure you ALWAYS buy from progressive RC or their dealer network, this way you can use your warranty.
Socket is offline
Old 06-27-2016 | 04:33 PM
I taped up the temp sensor port so that I don't accidentally plug the balance cable into it (assuming if you are using the smaller 2s balance port plug)
littleZEN is offline
