Tekin ESC Tuning and Programing >
Old 12-31-1969, 04:00 PM
R/C Tech Forums Expert How-Tos and Guides
Last edit by:
Print Wikipost
Last edit by:
Print Wikipost
Old 07-04-2016 | 06:55 AM
  #46
Souk's Avatar
Default Everything working now
After messing around with getting the new hotwire downloaded. I have played around with all the new updates And software over the weekend. I have figured out the new features and I must say my esc's are working awesome. Great job tekin on getting all the new stuff up and working so fast!
Souk is offline
Old 07-04-2016 | 02:50 PM
  #47
Originally Posted by cHAmpa
I just downloaded it from the Google Play Store, installed with no issues. Samsung Galaxy S6 Android Ver. 6.01
All features available, but some got cropped off in my screenshot.
I have an android tablet and use the Hotwire app but I still have the original Hotwire functions. How did u get to download the newer app? Did u Search Hotwire 2.0 or just Hotwire and it is the same icon?
Slashn77 is offline
Old 07-04-2016 | 05:04 PM
  #48
I cleared all data for the app, uninstalled it and then re-downloaded Hotwire from the Google Play store.
cHAmpa is offline
Old 07-04-2016 | 05:55 PM
  #49
Thanks for the response
How did u clear all data? Uninstalling and reinstalling isn't enough? (Because it hasn't worked for me)
Slashn77 is offline
Old 07-04-2016 | 06:01 PM
  #50
On My phone I went to Settings --> Device --> Applications --> Application Manager --> HW Beta --> Storage. Then selected "Clear Data".. I think it cleared cache as well, but if not, clear that.
Then I uninstalled the app. Went to Google Play and downloaded and installed the latest Hotwire version.
cHAmpa is offline
Old 07-04-2016 | 07:32 PM
  #51
Thanks man I'm gonna give it another try tomorrow!!
Slashn77 is offline
Old 07-04-2016 | 07:51 PM
  #52
You may even want to restart your tablet after you do the clear data and uninstall; then try and download again. I love Android, but it can be finicky when updating certain apps. Good luck!
cHAmpa is offline
Old 07-05-2016 | 01:58 AM
  #53
romanmotruk's Avatar
I bought this regulator to experiment with the logger, I'm not reprogrammed from the factory and used the factory firmware, the controller worked perfectly, it was the old firmware, it was possible to make rollback to old firmware, also enjoyed 3 hours, removed logs, the current showed 100-110-120 amps, the logger worked, but there was a problem with the fact that the log shows OK, but when you're trying to watch it from the computer's memory, there are no values, but decided to upgrade to the 255 firmware and got a "brick", ie the regulator is working but the adjustment current is limited, only 71.15 amps!!! on any motor, in any gear, is current limitter at 71.15, although regulator a maximum poonch, wrote in support of Tekin, but there is no answer! windows XP SP3
with this new firmware 255, there is a problem, as you say, he also reflash the firmware on 255 your the same controller, it is also now not flashed to the old firmware and now we don't know how to return the controller to its previous state!
can't register on the forum Tekin, need to be confirmed and no confirmation is coming!
representatives Tekin, please tell me, what do I do with this controller??? I tried another computer reflash on WIN 7, and still the restriction on 71.15 amps and gnarled log, when you open
photo of problem
romanmotruk is offline
Old 07-07-2016 | 09:46 AM
  #54
Randy_Pike's Avatar
Team Tekin
Romanmotruk; I've responded to this inquiry in the original thread.
Randy_Pike is offline
Old 07-07-2016 | 11:16 AM
  #55
Hey Randy, any update on the 1/8 scale RX8 Gen2 Driver Setups for the 255 release?
cHAmpa is offline
Old 07-08-2016 | 07:30 AM
  #56
can I ask you to update the firmware and remove the logs afterwards? after the upgrade, you will not be able to return to the previous firmware, remember that!
Old 07-08-2016 | 08:55 AM
  #57
Randy_Pike's Avatar
Team Tekin
IF you update the ESC the data logs are generally cleared out. We always suggest running the latest firmware on all Tekin products.
Old 07-08-2016 | 12:06 PM
  #58
I, too, was all good until I updated the firmware, now I had to send the controller in for repair, the next day after purchase, good quality! this is not the first controller Tekin, who has such problems we in Ukraine, all Tekin burned, for various reasons for 2 years, more than 8 pieces. and Hobbywing works without problems for years!
Old 07-08-2016 | 12:32 PM
  #59
Randy_Pike's Avatar
Team Tekin
You are still failing to point out your issue Roman. Are you now saying your ESC doesn't work after the udpate? Can you be more specific?
You've yet to give me a reason to even suggest sending in your esc.
Old 07-08-2016 | 04:10 PM
  #60
They're being posted shortly!
Hey Randy, I know you are lost in translation But any update on the driver setups? On Facebook they gave the impression they would be upldated within the day.. but that was several days ago.
Or perhaps you can message me or email me some setups if the holdup is getting them up on the website?
Thanks for all the work you do.
cHAmpa is offline
