Team Powers USA - Product Support
#76
#77
Can vs Actual timing
Can vs Actual timing on a Actinium V2 13.5.
This is my results as per SkyRc motor checker:
can avg A B C
0 22 25 17 23
10 28 30 23 30
20 35 37 30 37
30 41 44 36 42
40 48 51 43 49
50 53 57 48 54
60 60 62 54 61
can avg A B C
0 22 25 17 23
10 28 30 23 30
20 35 37 30 37
30 41 44 36 42
40 48 51 43 49
50 53 57 48 54
60 60 62 54 61
#78
It went really well for the 1st and 2nd qualifier (top 3) until I did something stupid. Move the timing up... and just lost all that punch and snap... and ended dead last. Went home checked the timing. Running at 51 deg average per motor analyzer; can says 38-40ish. Checked rpm and amp..... 8.7 ish. I stopped the motor analyzer coz it was whinning really high like the motor is going to explode. Saw the rpm numbers going past 28000rpm...then pushed the stop button. LOL
In conclusion. The timing is very very sensitive. And i should NOT screw around with the timing in the mains after i ran good runs in the qualifiers. Lesson learned .
I think my tires were just spinning out and didn't get any grip due to the power of the motor.
#80
i didn't get that reading. i just know 6amps was about 38 degrees on the can (don't know what the actual timing was).
#84
How is this motor compared to the Fantom M, V2r, and team scream? Thx
#85
For some reason , my Hobbywing XR10 Pro esc doesn't read the motor temp when the sensor is connected to the motor. I usually use ny esc to check motor temp. Anybodu has the same experience with this? My esc reads my Fantom and Reedy motors but not this Tem powers motor.
#86
#88
This is my first team powers motor 21.5 it does a great job so far. I like it a lot. I run on a very large track the straight away is a 130feet long and it keeps up with everything else out on the track in 21.5 tc out door asphalt
#90
