Team Powers USA - Product Support >
Like Tree6Likes
Old 03-22-2016, 04:05 PM
TeamPowersUSA's Avatar
Default Team Powers USA - Product Support
Hello Everyone. I would like to start this thread for all Team Powers product. I know we have a couple threads here on RCtech. I thought I would just make one that I can monitor consistently. Please let me know if you have any questions, or comments. Hopefully I can help with anything anyone might need.
allrc likes this.
TeamPowersUSA is offline
Old 03-22-2016, 05:50 PM
Default need help
I recently acquired a team powers radon pro v2. Im running it in stock buggy. It didnt come with a bec wire and I cant do any of the programming can you help find a place to get a new I seem to be having trouble getting one. Thanks in advance
Badcompny44 is offline
Old 03-23-2016, 08:33 AM
Hey BadCompany. Did you also email me about this? I replied to an email yesterday about this topic. I can get you setup either way. Shoot me an email. [email protected]
Thanks,
JimmyD
Old 03-28-2016, 12:58 AM
Default Radon V2 95a firmware 2.1
Any setups for 13.5 boosted .
Normally run gearing of 6.38 FDR with a hobbywing 3.1
Now switched to radon v2 95a with firmware 2.1
Thanks in advance
rharris72 is offline
Old 04-03-2016, 06:18 PM
fat500's Avatar
Trader Rating: 38 (100%+)
what size rotor comes in 21.5 motor
fat500 is offline
Old 04-07-2016, 11:27 PM
Thanks in advance
rharris,
We don't really run the 13.5 boosted under ROAR rules in the states. I have this setup from Asia. Maybe try to use slightly lower settings to start as this is for the Pro speedo. Of course make sure you pay attension to motor and speedo heat. Always run the fan.
TH1: Punch Rate A: 15
TH2: Punch Rate B: 20
TH3: TH SW Poiint: 50%
TH4: Slope: Linear
T1: Timing Boost: 38
T2: BT Start RPM: 6000
T3: BT End RPM: 17000
T4: Boost Slope: Linear
T5: Power Saving Mode: No
T6: Turbo Boost: 23
T7: TB Activation: TH
T8: Turbo Delay: 0.1s
T9: TB Start RPM: ---
T10: TB on slope: 24eg/0.1s
T11: TB off slope: Instant
T12: Turbo K LVL: 10
T13: Turbo T LVL: 0
Old 04-07-2016, 11:28 PM
The 21.5 motor comes with a 12.5mm rotor in the states.
Old 04-07-2016, 11:32 PM
The Radon 1S speedo has now been Roar Approved!
Old 04-08-2016, 08:26 AM
Cool.
Tony Vega is offline
Old 04-08-2016, 11:38 AM
angrymelon's Avatar
Hmm, guess a 1/12th scale might be in my future
angrymelon is offline
Old 04-17-2016, 11:28 AM
Default Thanks for the settings
I'm struggling with the braking effect on the radon v2 firmware 2.1
You can only set initial to 1% so I have and drag brake is set to 0 but the car still when coasting applies alot of brake .
Is it a software issue or am I missing something in the settings really struggling as it makes lap times so in consistent due to the wierd braking issue. And advice helpful
Old 04-18-2016, 01:48 AM
daleburr's Avatar
Rich, if you're running the Turbo Off Slope set to 'instant' as in the settings given above, this will give a massive drag-brake feel at high speed. Try around 6-12 instead.
daleburr is offline
Old 04-18-2016, 05:55 AM
Trader Rating: 23 (100%+)
what's the difference between plutonium and actinium motors?
phatboislim is offline
Old 04-26-2016, 04:23 AM
no one?
Old 04-26-2016, 12:01 PM
Tech Legend
Cain's Avatar
Trader Rating: 269 (100%+)
I got a team powers motor checker here, can it be used as much as possible (I know it doesn't have timing feature) to check motor performance like the G-Force Analyser? I figure I could look for similar RPM and Amp draw that someone recommends to see, and in theory it appears to work.
Cain is offline
