Like Tree3Likes
LiHV ?
Old 03-21-2016 | 02:52 PM
  #31
JayL's Avatar
R/C Tech Elite Member
So, basically we now have to tech at every spec club race, fun fun, slow slow
JayL is offline
Old 03-21-2016 | 02:54 PM
  #32
Team EAM
If you havent been teching already there is a 99% chance SOMEONE at your club has already been over charging packs not designed for it anyway.
EA
EAMotorsports is offline
Old 03-21-2016 | 03:21 PM
  #33
JayL's Avatar
EA
Yes, but they all had 8.4 batts. Now some will have 8.4 and some will have 8.7, thus the 'overcharge' range has been moved up from the 8.4's max overcharge to the 8.7's max overcharge.
JayL is offline
Old 03-21-2016 | 03:24 PM
  #34
Suspended
We were charging to 4.45 long before these batteries came out...
Socket is offline
Old 03-21-2016 | 04:48 PM
  #35
AE-Reedy
Yes, unfortunately the over charging came along right after lipos were introduced.
Not anything new, battery voltage is simple to tech and should be checked at all races.
If they aren't checking most likely someone is over the limit.
This assumes there is enough grip for it to matter.
Sean Cochran is offline
Old 03-21-2016 | 05:15 PM
  #36
JayL's Avatar
Yes, on 'old batts' people charged to 4.45, .25 above "normal" so now "normal" is 4.35 so people will charge to .25 above that, 4.6
can you see the difference between:
4.45/8.9v
and
4.6/9.2v
That's my issue:they guys with the new HV batteries can cheat EVEN MORE than the guys with non HV batts
With only one voltage battery you assume cheating but the cheating all has about the same MAX.
JayL is offline
Old 03-21-2016 | 06:11 PM
  #37
RedBullFiXX's Avatar
Questions??
4.45/8.9v
and
4.6/9.2v
So what is your solution ?
RedBullFiXX is offline
Old 03-21-2016 | 11:37 PM
  #38
Roelof's Avatar
The solution is simple. Drivers must come to technical inspection with an unplugged battery before they drive. TC will check the voltage and will detect overcharged batteries.
This has been a well known procedure but still you see people giving a lot of throttle before the voltage is checked, new rules say that may not be done anymore.
Roelof is online now
Old 03-22-2016 | 05:37 AM
  #39
Skiddins's Avatar
At least this thread is providing a nice list of cheaters for all to see Lol.
Skiddins is offline
Old 03-22-2016 | 05:48 AM
  #40
Skiddins's Avatar
Originally Posted by tps3443
Then don't use the advice, speaking of throwing money out the window, wouldn't that be what someone is doing spending $150 on a HV battery to charge it a additional 0.15volts.
We live in a world where things can be pushed to save money, because we want more power! My 3.3ghz i7 CPU is overclocked to 4.8ghz, with additional voltage and cooling. All of this for the cost of nothing. Because I can, my choice.
I put in my 2¢ I charge all of my batteries to 8.7volts, or 4.35 with no adverse affects.
I tested this on a few puffed 6 year old Turnigy packs.
I de puffed them, popped a hole with a toothpick, put it in a press gasses came out, and I hot glued the hole. These batteries are like new again.
A few have over 100 cycles without puffing. Lipos are a hit or miss, and we abuse them already as it is.
If you get a 100 cycles on a $30-$50 battery and it dies, you just about got what you paid for.
If you're worried about charging a standard Lipo to 4.35v, then please do not try this.
I have a certified Trinity battery I do not overcharge they run over $200 a piece and I choose not to so I can get 200-300 cycles.
A collection of some of the stupidest 'advice' we've seen on here.
As for spending $200 on a Trinity 'Certified' pack, THAT'S a good way to waste money
angrymelon likes this.
Skiddins is offline
Old 03-22-2016 | 07:56 AM
  #41
Rick Hohwart's Avatar
EA
You are being kind. I am sure it is 100%!
4.45/8.9v
and
4.6/9.2v
They can cheat more and be safer but the performance will not be better. Both batteries charged to 9V will run about the same assuming they are equal batteries to begin with (C rating, age, etc.).
Rick Hohwart is offline
Old 03-22-2016 | 08:33 AM
  #42
I am positive it is not 100%
many interesting points of view in this thread ...
Old 03-22-2016 | 11:43 AM
  #43
Suspended
I remember people over volting with Nicads....
Socket is offline
Old 03-22-2016 | 12:13 PM
  #44
There was no voltage limit back then either.
Andy Koback is offline
Old 03-22-2016 | 12:20 PM
  #45
Roelof's Avatar
No maximum charging curent either so people were peaking with 40amps or more.......
