Button programming on a DX4r pro >
Old 01-11-2016 | 10:39 PM
jason07's Avatar
Default Button programming on a DX4r pro
I'm wondering if someone can help me. There are 6 switches on this radio (A-F). The only button that is an on/off button is the F button, all the others are side to side type switches. I want 2 on/off switches, is there a way to do this?
jason07 is offline
Old 01-12-2016 | 03:26 AM
I don't think so. When modding the buttons you scroll available option for that button, I didn't see an on/off option.
The on off could be more of a circuit break then a programmed button, although I don't know for sure. I would think a circuit breaker reduces slow drain when off.
The DX4 is very very good on batteries. A decent set of AA's last a looooooooooooooong time.
Rac3rX is offline
Old 01-12-2016 | 04:21 AM
Any of the switches can be set to 2P (2 Position). Jumps to each position depending on which way its pushed.
Not a true off/on, just high/low servo position/PWM setting. A true off/on requires something like a picoswitch.
What are you trying to achieve?
Dave H is offline
Old 01-12-2016 | 03:56 PM
jason07's Avatar
I'm thinking about getting a Traxxas revo 3.3 for some fun bashing while I'm not racing. I don't want to use the traxxas radio. I have button F being used for the timer so I don't want to use that. I want the other button to be used for putting the revo in reverse. If someone has a better idea I would love to hear it.
jason07 is offline
Old 01-13-2016 | 02:31 PM
That should work fine. Choose 2P on one of aux channels for the chosen button, set travel on each to shift the gearbox correctly, and light it up.
Dave H is offline
Old 01-13-2016 | 09:58 PM
jason07's Avatar
awesome! thank you
jason07 is offline
