hyperion charger question
I have 2x 720i super duo 3 chargers,which have faults in the ballancing/section.
my question is .Can these chargers be used ,unballanced ,to say 95%,and then ballanced with an seperate ballancer,and if so ,can anyone sugest a ballancer that can be relied upon.
thank you,any advise wellcome here,i cant afford another $900.au to replace these!
no its a common fault with these cheap chargers,but thats ok,
What i need to know is , is there a good cell ballancer @300ma disc ,to use seperately with any charger ? so i can still use the fast charge capabillity of the 720 super duo ?
Sorry to hear you are having problems with your charger. Have you contacted Hyperion for a fix?
I have exclusively used Hyperion chargers for nearly a decade and I have never heard anyone complain of any "common faults" with them. If anything, they are rock solid for everyone I have spoke with.
But never a problem with charging. Where did you get the idea that Hyperion are cheap chargers? It may not be the almighty (sarcasm) iCharger, but they are NOT cheap chargers.
4 out of 4 balancers are bad? Seems unlikely. Did they ever work? Positive the balancer is being hooked up correctly? Are you using a balance board or a direct connection? Hyperion uses a different setup than the JST-XH that have since become more common. I know the Duo3 I have came with two pairs of balance boards, a set for Hyperion/Polyquest and a set for JST-XH.
$300AU,which is what i payed for these is a cheap charger.$2,000US is an expensive unit !
there not serviceable ,electronics need servicing to be reliable !
they are complex ,and they fail !
BUT they do charge at a good rate !
Now all i need is a ballancer ,or 2 ,ie 1 for each port ime good to go again.
and both of these 720 duuo chargers are no good for ballancing ,for a start ,whenballance charging they stop to chech cells every 10 seconds ,takes to/long.the readings are unreliable and cells get over charged all the time .these chargers killed every battery i own before i woke up/to it.the resistance readings are no good they stay the same untill the power is disconected ,even with no batt fitted the readings stay the same .
aass wwell as faalse readings .ive conected batts to both chargers without the unit being powered.maby thet wrect them
also,i think the ballance conections areno good ,if you give a wiggle all values change ,and some chanels allways give bad readings for the same numbered cell,regardless of battery.
And as far as i know Hyperion dont service anything
You continue to say how unreliable they are yet you seem to be the only one having problems with them. The fact that you are having the same problem with 2 different chargers leads me to believe that you caused the problem by doing something wrong. Maybe hooking them up not powered or like someone else said, using the wrong balance boards.
They are serviceable. They are complex because they have a lot of features, that make them customizable to do what you want them to do. If that is too much for you maybe the Traxxas iD system would be better suited to you. Balancing a battery properly takes time, so checking the rate often is a good thing. What exactly do you mean by over charging? Being that the menu is so confusing maybe you made a mistake with the setting causing them to over charge your batteries?
Honestly, I have a hard time believing this. Either your settings are messed, or a software update was done incorrectly, or your chargers are broken. This is not normal behavior for a Hyperion charger.
Did you buy these chargers new or used?
Yeah, I have 2 Hyperion EOS0720iNet chargers, and LOVE them. Only problem that I have ever had (which I have heard is common for them) is the fans will get noisy once in a while.
i just bwant to use the fast charge 50amp of my old hyperion, and ballance with something cheaper.
What?? $300 AUD is $213 USD, not cheap considering there are pretty good $60 chargers out there. $2000 USD could get you an entire race package new from a hobby store.
bloody mistake ,very easy to do ,and bingo chargers are toast.
If theyr servicable then where in Aus ?i can garanty you that the cost of freight will not be worthwile to fix .ime in north queensland ,no service here!
ALL I WANT is a bloody good ballancer ,@300mh to1000mh ,like the power lab .
i need a good ballaqncer is all.
I have personally never even heard of a $2,000 RC charger. Maybe complete with case, fans, power supplies, etc.
have a look around there everywhere.
I havent updated any software .cant do it.and i don't care what you believe.
It shouldn't have, but I guess anything can happen.
well something has happened.
Is it the balance board or the actual connector? Have you tried a new balance board or balance plug?yes tried everything.
ijust need a ballancer,a good one thats all!!!!!!!!
1Likes
