Hitec pad
Old 05-03-2015 | 08:06 PM
jose valadao's Avatar
Default Hitec pad
Witch receiver do I use the hitec pad or do you use it on all receiver .
jose valadao is offline
Old 05-04-2015 | 04:12 AM
Not sure what the pad is you are asking about?
Dave H is offline
Old 05-05-2015 | 09:24 PM
The pad comes with the new servos
Old 05-05-2015 | 09:29 PM
Mopar2Ya's Avatar
You plug P.A.D. into an unused port on your receiver(any receiver powering a Hitec brushless servo). From Hitec:
June 2014: Brushless Servo Service Bulletin
While compatible with most radio control devices, the regenerative braking feature of the HSB-9XXX series servos may cause a problem if the device cannot accept a backflow of current. The types of devices that cannot accept this backflow are: Voltage Regulators, Power Safe Receivers and certain BEC circuits whether stand alone or integrated within an Electronic Speed Control. Check with the manufacturer or the Hitec website for a list of compatible models. If your device cannot accept a current backflow, then you must install a PAD (Power Absorbing Device - Hitec PN# 55756) as described in this manual. A PAD is included with every Hitec brushless servo.
Mopar2Ya is offline
