DIY sensor wire questions >
Old 03-14-2015 | 05:55 PM
Default DIY sensor wire questions
Has anyone built their own? I would like to, but cant find any info on what the parts are called or where to find them. Any info would be appreciated.
seanhawk is offline
Old 03-14-2015 | 06:13 PM
wingracer's Avatar
Go here for the ROAR rulebook:
http://www.roarracing.com/downloads/..._Rule_Book.pdf
And scroll down to page 45. Complete list of the connectors with part numbers.
wingracer is offline
Old 03-14-2015 | 07:39 PM
Thanks, those are referring to the male end of the sensor. Any idea of the female end?
seanhawk is offline
Old 03-14-2015 | 08:14 PM
Will this tool crimp this small of connector?
http://www.amazon.com/Engineer-PA-09.../dp/B002AVVO7K
http://www.digikey.com/scripts/DkSea...46194406590204
Im confused if the pin is .5mm or 1.5mm? If it's 1.5 this tool should work fine, correct?
seanhawk is offline
Old 03-15-2015 | 02:45 AM
Roelof's Avatar
Both ends share the same connector. But why do you want to build your own sensor cable?
Roelof is offline
Old 03-15-2015 | 03:28 PM
Yosh70's Avatar
+1
If they were expensive, I could see......but $4-5? Hardly worth it.
Yosh70 is offline
