Blinky Rules
I don't know why, but a lot of people think you cannot use the timing on the back of the motor in stock spec, that it has to be set to zero. I had a friend complain he was getting killed in stock spec, and I asked what timing on the back of the motor he was using, and he said none because it is stock spec.
So the big factor in stock spec is not allowing you to set up a custom power curve to include boosting parameters, so the power available is a linear curve. I can still go faster than I need @ 25* timing. I guess this is why everyone in stock spec is buying the 100C batteries as well.
The zero degree on the motor is also different among brands. The one is real zero, some have +10 and there are motors with +30 degrees.
To prevent this in a lot of stock competitions the motor is determed. Just one like with the ETS or a few as I do see on several clubraces.
25C - can apply maximum power for 3 seconds
50C - can apply maximum power for 5 seconds
90C - can apply maximum power 8 seconds
100C - can apply maximum power 10 seconds.
You can see an advantage down the straight or a big jump. Especially if you have a amp drawing motor and need that boost for the big table top or triple.
