Full throttle glitch master crash break. >
Old 01-12-2015 | 01:16 AM
Default Full throttle glitch master crash break.
Sct410
Sct pro Esc
M12 radio
4.5 550 motor.
1258 tg servo
Sometimes when I am driving the car glitch out and hit full throttle. It caused me to crash and bust my truck. What causes this and how do I fix it? Glitch buster?
Boostgod is offline
Old 01-14-2015 | 10:56 AM
MarkA's Avatar
Savox servo = you should absolutely start with a glitch buster.
MarkA is offline
Old 01-14-2015 | 11:13 AM
DRTMI's Avatar
Super Moderator
Glitch buster or a BEC. I use a BEC on all my rigs personally. On an 1//8 scale it won't even notice the weight that one adds, and you can adjust the voltage to suit you servo. I use mine with a by-pass harness so the BEC only runs the servo and the ESC powers the receiver.
DRTMI is offline
Old 01-14-2015 | 12:31 PM
kingofcool999's Avatar
+1. If your ESC doesn't have a 5A BEC, forget about it. Use an external BEC.
kingofcool999 is offline
Old 01-26-2015 | 04:33 PM
What is a BEC?
Boostgod is offline
Old 01-26-2015 | 06:57 PM
Battery Eliminator Circuit. In a traditional setup they eliminate the need for a separate receiver battery in an electric model to power the receiver and servo(s).
Most speed controls have a BEC built in, and there are separate (external) BEC units available that can provide more power. Sometimes called a voltage regulator, as they lower and regulate the main pack voltage to a level the receiver and servos can work with.
Although some servos and receivers are capable of higher voltage and can be ran on a 2S lipo pack without the need for a BEC. Higher voltage packs, like a 4S for example, normally still need a BEC.
Dave H is offline
