Will slowing it down make smoke? >
Old 10-29-2014 | 01:34 PM
pacnwfoto's Avatar
Default Will slowing it down make smoke?
The plan is to run a Mini-Z MR-03S around an obstacle course in a small indoor space. So, I need to slow the car beyond what the small pinion can do. Putting a resistor on the + side of the motor should work, but will this damage the ESC?
pacnwfoto is offline
Old 10-29-2014 | 01:50 PM
howardcano's Avatar
You might fry the resistor (it's going to dissipate quite a bit of power), but not the ESC. Do you have the ability to turn down the throttle endpoint? That would be much easier than anything else.
howardcano is offline
Old 10-29-2014 | 03:54 PM
pacnwfoto's Avatar
Originally Posted by howardcano
...Do you have the ability to turn down the throttle endpoint?.....
Thanks for the feedback. The KT-19 Tx has a not-slow-enough [for me] 'training mode' but no throttle endpoint adjustment.
