Will my setup cause a brownout? >
Old 09-14-2014 | 12:24 AM
Default Will my setup cause a brownout?
Hey guys,
I have just built kyosho mp9e 1/8 buggy.
It has savox 1256 tg servo, 6000 mah 4s 70c battery, sanwa mt4-s radio & receiver and hobbywing 150a esc 2250 kv motor. Will this setup cause a brownout?
marchoman is offline
Old 09-14-2014 | 12:06 PM
kingofcool999's Avatar
How many amps is your BEC rated for? If it's less than 5A you could have some issues. If you are having problems, a glitch buster cap would help, but it's more of a band aide than a real fix.
kingofcool999 is offline
Old 09-14-2014 | 12:17 PM
These are the specs if it helps:
1.1 Output: Continuous 150A, burst 950A.
1.2 Input: 6-18 cells NiMH/NiCd or 2-6S LiPo.
(When using 2S lipo or 6 cells NiMH, an UBEC or seperate battery is strongly recommended to supply the receiver)
1.3 BEC: 5.75V/3A (Switch mode built-in BEC).
1.4 Resistance: 0.0002 Ohm.
1.5 Motor Supported: Sensorless and sensored brushless motors.
1.6 Suitable Motor: * Note #1
When working with 4 cells Lipo: KV<=3000
When working with 6 cells Lipo: KV<=2400
1.7 Suitable Car: 1/8 On-road/Buggy/Truggy/Monster competition.
1.8 Size: 58mm(L) * 46.5mm(W) * 35mm(H).
1.9 Weight: 105g (Without wires).
Old 09-14-2014 | 05:49 PM
nexxus's Avatar
Super Moderator
Shouldn't do, Sanwa radios aren't prone to brownouts like Spektrum
nexxus is offline
Old 09-14-2014 | 07:49 PM
Nexxus might be right, but that servo can pull 5 amps when stalled (or shocked, like when landing a jump). Your BEC can provide 3 amps. Eventually something's gonna give.
Old 09-14-2014 | 07:55 PM
ok so how do i avoid a potential brownout?
Old 09-14-2014 | 07:59 PM
You might get by with a glitch buster capacitor plugged in to your receiver. You might have to use an external BEC. You might need nothing. Won't know until you try it out.
Old 09-15-2014 | 05:56 AM
lbenton's Avatar
A glitch buster cap is cheap enough to just get and see if makes a difference. I have seen a case or two where dry steering is improved with a cap vs without. For a few $$ you can just see what it does.
lbenton is offline
Old 09-15-2014 | 12:14 PM
thanx guys.
