To discharge or not
Old 08-11-2014 | 08:04 PM
subaru73's Avatar
Default To discharge or not
I have a burning question is it really needed to discharge a lipo battery after running?I am running 2 s 6500 battery in on road . Is there any performance advantage or harm to the battery. Let the debate begin
subaru73 is offline
Old 08-11-2014 | 08:15 PM
Suspended
I always keep my lipo's at a storage charge when Im not using them for 36 hours or more..
so Yes discharge them to a storage voltage when not going to use..3.6v a cell 3.75 is ok also.
ElectricMann is offline
Old 08-11-2014 | 08:31 PM
CraigMBA's Avatar
CraigMBA is offline
Old 08-12-2014 | 12:29 AM
Salkin's Avatar
When I'm done with a lipo after a run, the voltage rest at about 3,7V - 3,8V.
Would it be OK to leave them at that voltage, or should they be discharged to a lower voltage?
Salkin is offline
Old 08-12-2014 | 05:18 AM
howardcano's Avatar
I have had good luck with those voltages.
howardcano is offline
Old 08-12-2014 | 05:24 AM
longuylander's Avatar
What are the detriments to the battery if a battery is fully charged but then left to sit for a week? A month?
longuylander is offline
Old 08-12-2014 | 05:32 AM
lbenton's Avatar
As a rule, you only need two settings on your Lipo charger.
Balance and Storage
If you plan to put it up a while storage charge it, many chargers do not discharge very fast and a large capacity lipo might take a while, may take more than one pass if it was fully charged.
But all the other functions can be ignored and you will have a healthy lipo life cycle. I would not discharge it on the charger, that will run the voltage down too low for storage.
lbenton is offline
Old 08-12-2014 | 06:07 AM
Salkin's Avatar
Thanks.
Salkin is offline
Old 08-12-2014 | 07:00 AM
Hoese37's Avatar
Just get it to its nominal voltage and you will give it its longest life possible. Leaving it fully charged can lead to very high IR, getting out of balance, and even puffing the pack.
Hoese37 is offline
Old 08-12-2014 | 07:48 AM
whitrzac's Avatar
You get buy a new battery...
whitrzac is offline
