Trinity D4 17.5
#316
Super Moderator
Hi Erik, I am very intrigued by this piece of equipment! Could you please tell me little bit of what is does and the benefits as I have quite an arsenal of 17.5 motors including a new 17.5 Certified Handbuilt D4 Big Blue that I have not even tried yet. Your time is greatly appreciated.
#318
My heads still spinning!! Lol.
#319
Anyone have any experience with the D4 Certified Big Blue motors vs the Maxzilla?
#320
You cant really compare the 2. The Big Blue is not ROAR legal due to the wire used in the stator construction. The Maxzilla is ROAR legal. I would assume the Big Blue has a ton of bottom end power. I run the Maxzilla(Certified) in all stock classes and it's a beast. Plenty of power and doesnt fade. Great motor!
#321
Fair enough. So comparing the standard Maxzilla vs the Certified Maxzilla is there a noticeable difference? I am getting walked on by a Killshot and am currently running the D4 Maxzilla (Standard) and the killshot passes me down the straight like I am in a school zone and leaves me out of the hole like I forgot to put it in gear...lol
#322
R/C Tech Elite Member
Maybe that guy is cheating somehow?
#323
You should not be getting walked by any motor other then another D4. What is your set up? Vehicle,gearing,battery?
#324
The D4 comes standard with a 12.3mm rotor. The D4 Maxzilla comes standard with a 12.5mm HT rotor. The Certified motors are similar to the Maxzilla with a 12.5mm rotor but they are hand built to very high standards.
I am running a B5M, Inline battery setup, Tekin RS Gen2 ESC in Blinky, D4 Maxzilla, 33/69 or 34/69 gearing with 50* can timing, 4600mah 100c Prime Battery or 4500mah 100c Trinity depending on which one is charged.
I know that my motor runs strong because I don't have any issues other than this Killshot that does straight walk on everyone else. Just to give you an idea I would say average fast lap time right now for stock buggy is around 15.3-15.5sec for the A Main drivers. This guy is running 14.7-14.9sec fast lap times
#325
based on your last paragraph, it would seem pretty likely that the guy is cheating. killshots are strong motors no doubt, but "walking" a D4? highly unlikely. i could see it being comparable or MAYBE a virtually unnoticeable tick faster, but again, "walking"? i think something's up with the guy's motor.
#327
I know that the Maxzilla comes with the 12.5mm rotor. I have owned both the 12.3 D3.5 and the Maxzilla D3.5 so when the D4 Maxzilla that is what I bought.
The V5 is a D4. If you remove that label it says Trinity D4. Fantom uses the Trinity motor for a base and offer some of there own upgrades and tweaks. This is very similar to the Certified 5% line Trinity offers. They are all D4's though.
#328
30/72 seems low for stock buggy. That's the same gearing I run in my SC10 17.5. I'll give it a go though and see. Nothing to lose by trying
#329
The reason for the lower gearing is because you are increasing the timing on the motor. How big is the track you race on?
#330
You're right, I just checked my SC10 again and I am running 26/72 on it currently. I still think that dropping down to a 30/72 is going to kill top end. I will try it and see. Worst case scenario I will change it back or adjust it anyway.
