ESC Amperage Help
Old 04-07-2014 | 02:04 PM
TLR Chipmunk's Avatar
Default ESC Amperage Help
I am looking at purchasing a Hobbywing esc for a Tekin 8.5t motor. What amp esc is required to run this motor?
TLR Chipmunk is offline
Old 04-07-2014 | 04:27 PM
Yosh70's Avatar
If you are looking at HW ESC's, they all say what motor it is suitable for....on Hobbypartz website anyways. Even with variables like on/off road, 2-3S lipo etc, its hard to go wrong.
Yosh70 is offline
Old 04-07-2014 | 07:25 PM
Well it says a 60amp is enough but is it going to be bear minimum and over heat easily because i have done little research and alot of people run 120amp but i was more wondering if a lower amp esc would run the motor.
Old 04-07-2014 | 07:29 PM
ThePanda's Avatar
Really I would look at the v2.1 90 amp at minimum. It can be had on ebay still. For a little more peace of mind the 120 amp v2.1 and the newer v3/v3.1 would be a better choice.
ThePanda is offline
Old 04-07-2014 | 08:19 PM
Took me a bit to find it, and it's not the easiest to read. That being said, these are the logs from my eagletree with a Novak Ballistic 8.5 in a stadium truck. Max draw was just over 53 amps. So, I'd go for the 90 or 120 myself.
ufoDziner is offline
Old 04-07-2014 | 08:24 PM
nexxus's Avatar
Super Moderator
Keep in mind a 60A Esc is rated at 60A Constant with a burst current rating closer to 100-150. For example the Savage Flux will pull 120-150 Amps on a burst but the Mamba Monster ESC behind it is only rated at around 80 Amps continuous. It also depends on application, a 4wd Buggy will pull more amps from a 10.5 motor than a 2wd one would. I'd say a 60A Esc would more than suffice, but if the price is only a few $ extra go for the 90 or 120, better to have a bit more wiggle room
nexxus is offline
Old 04-07-2014 | 08:39 PM
I agree, I just don't like to be that close to the max continuous if I don't have too. Like you, it's only a few bucks and I can run a faster motor if I want.
Old 04-08-2014 | 04:57 AM
Thanks guys I'll go with the 120 amp.
Old 04-08-2014 | 06:06 AM
dan_vector's Avatar
I use the HW 2.1 90a with a tekin redline gen2 8.5t in a 4wd Cat K1 Aero buggy. Works fine and stays relatively cool even with quite a bit of boost set.
dan_vector is offline
