ESC problem
Old 03-12-2014 | 08:57 PM
Default ESC problem
Hello to everyone. I am using 4 ESC (pent 30a continuous burst 40a to 10 sec) on a quadrotor, and I cannot get them to turn my motors. what type of lipo battery should I be using?
this is my setup
1200kv motors x4 1.3a unload current max current 21a
Naza Lite GPS
Spektrum DX6i transmitter
j holmes is offline
Old 03-12-2014 | 09:16 PM
ThePanda's Avatar
what batteries?
ThePanda is offline
Old 03-13-2014 | 12:50 AM
dan_vector's Avatar
Probably something like 3s 2500mah 25-30c
dan_vector is offline
Old 03-13-2014 | 03:46 AM
Default battery in question
I am trying to use either
1. 3S 11.1V 2100mAh(23.5 Wh) 20C(42 Amp)
or
2. 11.1v 3 cell 20C continuous discharge (100A) 5000mAh
max burst rate 40C (200A) min discharge volts per pack 9.0V
max volts per pack 12.6v
having problems starting my motors. I cant tell if it is the lipo or the ESC
j holmes is offline
Old 03-13-2014 | 08:27 AM
dan_vector's Avatar
or
Either of those is fine. I'm using 3s 2200 25C packs on my phantom quadcopter and thats plenty of power. I believe it'll be some issue with your setup of ESC etc. Go through it step by step, re bind, re calibrate and start eliminating things.
Old 03-13-2014 | 09:13 AM
Thanks I will keep on trying to figure it out.
j holmes is offline
