First time charging LiPo, need help.
I bought a HiTec X1 and have a SPC LiPo 6500mAh 7.4v 2S2P 65c 48.1Wh
I watched a couple of videos on what settings to use and they said to charge at what the mAh rating is.
So my 6500mAh should be charged at 6.5A but, the charger only goes up to 6.0A
Is it okay to charge at a lower amperage?
As long as the charger is set on lipo mode correctly, the charger will take care of the volts. They should rise up to 4.2V per cell, 8.4V total for your 2S pack, then the amps will drop off as it holds the voltage to top off the pack.
Personally I wouldn't take the time to charge at a lower amperage, modern lipos can easily handle a ~1C charge rate without issue.
quote: "The slower the better for the health of the battery. If you have the time, charge at 50%"
Yes, slower charge rates are acceptable but really unnecessary.....in the case of the OP he's stuck with the output of his charger. But charging at .5C or lower doesnt provide any benefit to the life of the battery.
Uhm, not really what he said.
