Like Tree15Likes
Tekin Hotwire App!!
Old 04-22-2014 | 02:25 PM
  #481
Randy_Pike's Avatar
Team Tekin
Originally Posted by Stubbs
Hey Randy, if you'd like to add another product to the list of Android devices the app works on, here's mine.
I picked up an ASUS Eee Tablet (model tf101) from one of the IT guys here at work. I wanted something better than the cheapo models from Wal-Mart.
Downloaded the app, and hooked up my Gen-1 Hotwire.....no problems at all connecting and changing settings on either of the two RX8-Gen 2 ESC's that I have.
I'd still prefer it if this app worked on my iPhone, but getting a tablet that retailed at $450 for $85, and I can use it for more than just RC stuff, takes some of the sting out of it.
Perfect, tablet added to our list. Thanks.
Randy_Pike is offline
Old 04-22-2014 | 02:52 PM
  #482
RoosterXp's Avatar
Gen 2 hotwire and gen 2 rs work great with my Droid Razr HD. I was a little skeptical but it works great!!! I am switching all my gen 1 over to gen 2... unless you guys are telling me something..
Awesome product Tekin!!
RoosterXp is offline
Old 04-22-2014 | 03:07 PM
  #483
Randy_Pike's Avatar
Team Tekin
The Gen1's are supported on the app now. Not much more to say really
Old 04-23-2014 | 10:14 AM
  #484
Originally Posted by fq06
You can not possibly hurt anything so don't worry about that.
Hotwire is female mini so you would need male mini to male micro... shorter the better.
Or female USB to micro male if your using the supplied cable, two ways to do it.
Hotwire comes with the male mini to male full size USB to hook up to laptop/notebook.
For older droids, hook up lipo, turn on ESC, connect hotwire.
Thanks, yes OTG cable on the way, if that works I'll try for the mini to micro USB to avoid the larger cable. Good to know on the power up, concern was what if I forgot my esc was powered on and used the tracks 1.0 which is hooked to their computer ?
BTW Moto Razr xt910 says it supports OTG, we'll see next week.
Photolad is offline
Old 04-23-2014 | 10:20 AM
  #485
Originally Posted by Randy_Pike
Don't over think this. Simply pick up "OTG Cable for XXXX" Device. Change the XXX to your device and search on Amazon or Ebay.
1. Download the App
2. Hook up the Hotwire to the esc and OTG cable.
3. Plug in the Hotwire/OTG to your device.(Note the first time a prompt will come up asking if you want future plug ins to automatically launch the app, click yes)
4. Launch the App.
Simple.
To test your device OTG abilities I've found it best to load a video file and or audio file onto a USB thumb/jump drive. Plug that into the OTG and then into your device. IF you can play the files from the drive...you should be good to go. IF not your device may not support OTG.
Thanks Randy, yep an over thinker and still manage to screw things up
OTG cable on the way, we'll know next week.
Photolad is offline
Old 04-23-2014 | 02:06 PM
  #486
Just used the PC version of the App today and not getting any RPM resultings from it.
moch8 is offline
Old 04-23-2014 | 03:42 PM
  #487
Randy_Pike's Avatar
Team Tekin
Ok, what esc are you using? Did you just flash the esc to new software? Did you make sure "RPM" is checked off in the data logger?
Old 04-24-2014 | 04:39 AM
  #488
Using the RS2 Esc. The software was flashed a little while back with 249 but only ran it for the first time. Don't know if RPM was ticked, will try again and see how it goes.
moch8 is offline
Old 05-08-2014 | 11:01 PM
  #489
ChuckTee's Avatar
OK I am trying to use the hotwire 2.0 with my LG G2and I cant get it to connect or boot up I guess , get it all hooked up and then the lights on the esc and the hotwire are blinking really fast and the screen loads but with the option bar at the top but nothing below. Any help appreciated.
ChuckTee is offline
Old 05-09-2014 | 08:05 AM
  #490
mo's Avatar
mo
It works on my Sprint LG G2. Do you have the latest update (250) in the speedo? You will need to upgrade on the computer first if you do not. Make sure you plug the hotwire into the speedo before you plug into the phone. Then it should launch or ask if you want to launch the app.
mo is offline
Old 05-09-2014 | 01:49 PM
  #491
ChuckTee's Avatar
Thanks for the help man, I will do this and I'll let you know how it go's
ChuckTee is offline
Old 05-12-2014 | 08:12 PM
  #492
symmetricon's Avatar
Will the app work on a note 3 running 4.4.2? I have the my phone, the app, a micro usb to mini usb, and and a hot wire 2.0, I can't seem to get my phone to detect the hotwire... any tips?
symmetricon is offline
Old 05-12-2014 | 08:38 PM
  #493
fq06's Avatar
Not sure about your specific droid but try powering the ESC with the lipo. Worth a shot.
fq06 is offline
Old 05-12-2014 | 08:42 PM
  #494
Thanks, I tried that but it didn't work...
Old 05-12-2014 | 08:56 PM
  #495
fq06's Avatar
Maybe someone else has a gem of info but in its absence sometimes removing programs and reloading works things out.
Try remove app and install it again. Still doesn't work? Try remove the hotwire software and download it again. Hard reset on ESC and update ESC.
I assume your on the 250 firmware already.
fq06 is offline
