What Airtronics MT-4 Receiver >
Old 12-16-2013 | 12:47 PM
Default What Airtronics MT-4 Receiver
Do not need telemetry. Grandson's mt-v seems just as fast as my mt-4. Any ideas on what receiver to go with?
Micah123 is offline
Old 12-16-2013 | 01:50 PM
BillyT.'s Avatar
I use these and the 461s... can't tell a difference.
Looks like the MX-V RX will work as well.
BillyT. is offline
Old 12-16-2013 | 04:06 PM
thanks for the info. nice to know speed is ok vs std rx that comes with the mt-4
Micah123 is offline
Old 12-17-2013 | 11:07 AM
+1 on the 92524
I use them with the rx461 and can't tell a difference between either.
hyujmn is offline
Old 02-14-2014 | 05:53 AM
Just checking to confirm no noticeable difference in latency with this receiver.
Micah123 is offline
Old 02-14-2014 | 07:24 AM
asc6000's Avatar
Superman couldn't tell the difference.
asc6000 is offline
Old 02-15-2014 | 05:45 AM
guess if it is good for superman, it should be good for me. thanks for the input.
Micah123 is offline
Old 02-15-2014 | 02:39 PM
if you get a 524 when you set it up to the mt4 it will ask you if you want to set it up as a 4 channel or two channel set up also with the 524 to bind it u need to change your modulation from fhs4 to fhs2 because the 524 is a fhss 2 mod. it works great with in my jammin x2 you can even set the fail safe the 524 supports. Michael
stoney452 is offline
Old 02-15-2014 | 02:41 PM
Danalle's Avatar
92524, I have 5 of them.
Danalle is offline
