SC1300-DB Question?
Old 12-02-2013 | 10:37 PM
Default SC1300-DB Question?
Hi im new to this forum, but not new to the hobby. I've heard good things about this forum and I thought I would try it out. Well, lets get down to business shall we! I was looking at this ESC and I wanted to run a single 4s instead of two 2s in series. But, I see a thin black wire coming from the ESC and into a place that's kind of hard to describe so bear with me.
I included pictures to hopefully help you guys help me... I don't know what it is and it is the first time I have EVER seen it on an ESC before. Im scared to cut it and when I do wire it up to run a single battery what do I do with that little thin one? Also, what does it do?
Attached Thumbnails SC1300-DB Question?-httpwwwmodelesklepplplkatalogregulatoryregulatory-team-associatedae-29146-xp-sc1300-db-brushless.jpg   SC1300-DB Question?-20130602_123550.jpg
Jojobeans is offline
Old 12-04-2013 | 12:10 AM
No one knows? Dang... I guess ill have to wait for Associated to reply to my email then.
Old 12-04-2013 | 03:41 AM
Just a wild guess, but it might be power for the BEC section, so it wouldn't need to drop as much voltage? If I remember right Novak I think it was once had a similar deal.
Dave H is offline
Old 12-04-2013 | 06:23 AM
Darkgenerals's Avatar
R/C Tech Elite Member
Would make sense, It also looks like a setup to measure the voltage of each pack. Maybe for a lipo cutoff?
Darkgenerals is offline
Old 12-04-2013 | 09:59 AM
It for the BEC, they emailed me and told me that I need to shell out more money and buy the sc1300-bl in order to run a single 4s. This sucks. Is there any way around this? Or am I SOL?
Old 12-04-2013 | 10:17 AM
Rick Hohwart's Avatar
This is exactly how it is set up. This way the LVC will kick in if either battery falls below the limit. It is not possible to run a single 4S battery.
Rick Hohwart is offline
Old 12-04-2013 | 04:31 PM
I made a jumper cable, plugged it up to the side without the tiny wire and the battery up to the side with the wire. It works, the fan kicked on, motor turned, servo turned, etc..
@rickhowart as I said in my earlier post AE emailed me and told me its for the BEC, not the LVC.
Old 12-05-2013 | 07:34 AM
Maybe route the little wire to the middle of the 4S balance tap to be safe?
Dave H is offline
Old 12-09-2013 | 12:32 AM
Ran it today, ran perfect. The lvc turned on, it ran with out issues... So AE, take that!
Old 02-28-2014 | 05:54 PM
Default xp sc1300 single battery
Jojobean, can you give me détails on how to modify the esc to operate single battery ? I dont really understand all the thread because im basically french. I want to use this combo in a ofna mbx buggy.
At least can you poste some pictures or send me at [email protected] thx a lot
koala2610 is offline
