Sanwa Super Vortex Zero ESC
#136
I've got kind of an odd question but does anyone know if the solder posts on the SV-plus zero are pre-tinned?
Because it does look like there is a mound of solder on each one but I'm not sure if I can just tin a wire and fuse it to the post without any extra solder.
#137
I have been looking and can't find any info on what to adjust on the Super Vortex Zero that is equivalent to a punch setting. I want to play around with punch rates but I'm lost.
Ps. This is not the gen 2. I'm using a mt-s and rx-482.
#138
waiting to test my Gen2 in 2wd xray..
#139
Does anyone know if the programming box will work with the SV-plus zero (the dual ESC and RX version)?
All I can find is documentation on it working with the ESC only version of the Super Vortex.
Thank you.
Thank you.
#140
Same goes for brakes. Higher numbers gives smoother brakes.
For VTA and stock, I use the lowest numbers for brakes and throttle. For higher turn motors and F1, I mash the throttle out of a corner and keep increasing the number until the rear tires don't slide.
#141
I understand correctly, it only works with the newer Super Vortex Gen2.
#143
As far as I am aware the program box will not work on the dual ESC/RX unit. I would be really happy if it could though lol
#144
Hello I’m new to the electric scene. I picked up a new Sanwa sv plus zero combo speedo and want to run it in a 4wd buggy with 6.5 motor. Is this speedo good for that or to much? I will be racing it at club races thx in advance
#146
Your ESC is nice but does not have any punch control . The type D has this option it is called "Throttle Response" . If it fits please install the fan it's way better overall to have it .
#147
I have just purchased a Super Vortex Zero #107A54113A I trying to link my SSL from my MT-44 transmitter which Aux1(Code 10) or Aux2(Code 5) and the instruction manual show 12 programming mode but the Sanwa wedsite show only 8 programming mode. Which is which so confusing. Please advise thank you.
#148
#149
you need to be aware that Sanwa limited the choices on what you could change remotely the first 4 settings can not be change via remote , you need to do this by yourself with the complicated menu navigation (led colors etc etc) to change those settings. Please take your time and activate reverse and bump up the temp settings (menu 3 to a higher setting) and activate option 4 if you need boost and timing options.
Aux 1 will give you the first 5 settings
Full Brake rate , Neutral Brake rate, Drive feel , Neutral Brake feel, Brake feel
and aux 2 will give you settings for boost if you need it
Boost timing (Advanced timing), Turbo , Boost curve
https://www.lrp.cc/fileadmin/product...107a54253a.pdf
the manual that came with your ESC should explain all of this ..
#150
Yes it's indeed a bit confusing but you need to set your aux1 in code mode not code 10 .
2Likes
