Sanwa Super Vortex Zero ESC >
Like Tree2Likes
Old 06-13-2016 | 10:45 PM
  #106
Originally Posted by voodoo
The aux2 can only be used as a +- plug for transponders and such if you enabled the Aux2 in SSL in your tx. To use your gyro in aux2 you have to set aux2 in your tx as normal and adjust aux2 functions manually. I also have a type d with built in rx on my f1 and i already tried using a gyro without any problems, but didnt need the aux2 settings so it was easy for me.
Thanks for reply. yes i tried setting it normal for aux2 but still cant seem find which adjustment is controlling the gyro.
CH121S is offline
Old 07-30-2016 | 08:35 AM
  #107
Originally Posted by CH121S
Can any help me with the AUX 2 plug. I dont understand it and havent got it to be in use.
i have SV Plus Type D with a MTS. ive gotten the SSL Setup and i can control all the AUX 2 Codes. but i was trying to be able to control My Gyro (non Sanwa) to be adjusted through remote. i cant figure it out. Do i need to use the Y-Harness?
Thanks in advance.
if i cant figure this out. im considering this a downside of being integrated RX/ESC
Hi i ve the MTS with sv plus zéro. Actually code aux to control the Speedo does'nt work. It does'nt modify Speedo parameters? Ssl is on ans telemetry work well
Any suggestion?
ben64 is offline
Old 09-07-2016 | 07:27 PM
  #108
jeromerc's Avatar
Looking at picking one of these up. I have the new antenna less receivers, will I be able to use the SSL with these receivers? Also is the combo unit any good, it is only like $40 more than the standard one, and would both be good for 2wd mod buggy/truggy and the 4wd buggy? Would you recommend the standard one or the one with built in rx? Switching over from Tekin and thinking this one or the Reedy brand but I already have the 4s remote
jeromerc is offline
Old 09-07-2016 | 10:30 PM
  #109
Does the Orion or Hobbywing switch work on the Sanwa esc?
I've been running these esc in my buggies for a year now without a problem. Took the new rb6.6 out today and the battery must of moved and taken out my switch... now I'm unable to switch it off. I can pull the power but I like my buggy fully functional.
Kuya_Kimo is offline
Old 09-08-2016 | 09:09 PM
  #110
jeromerc's Avatar
I lost a switch on my tekin and I live in Vietnam, and no hobby shop sells any two wire switches, to make a long story short, you can use a normal switch but you will have two wires going into one, and one going into one with the other wire being left alone, it might not be ideal, but for me it worked until I could order a switch off amain and get it sent out (took about a month) I know this isn't your question but basically any switch (12 volt) will work, you could even run a toggle switch if you wanted to. Just snip the wires from your switch and hook them up to the esc switch wires and you will be good to go. I ended up getting the western robotics power switch and it worked great. I think the only problem would be if the setup button is on the power switch like it is on some esc's
jeromerc is offline
Old 09-12-2016 | 11:32 PM
  #111
Thanks for the reply. My biggest concern I have is for the setup button, looks like I'll give it a shot and let you know. I've always like the Orion power button better.
Old 09-29-2016 | 10:46 AM
  #112
482rx can use ssl
481rx can't
I would get the new gen2:
http://sanwa-denshi.com/rc/car/speed...eration_2.html
but whatever one you get they can be used in all classes/cars you mention
atomic garden is offline
Old 09-30-2016 | 06:21 AM
  #113
Originally Posted by atomic garden
Just make sure that you have the right transmitter if you want to set all the supported ESC parameters over the radio. In that case, AUX1 channel on the transmitter has to be switched to CODE10, which is only supported by M12S and EXZES ZZ.
Related part from the manual: WARNING: M12, EXZES Z, MT-4S, MT-S don't have CODE 10 function. CODE AUX of M12, EXZES Z, MT-4S, MT-S can change values only for throttle punch/neutral brake rate/drive feel/neutral brake feel/brake feel.
This means, that out of 10 remotely-controllable ESC parameters, only 5 can be changed with transmitters other than M12S and EXZES ZZ (unless I have misunderstood the manual badly).
BTW - does anyone have any idea what the motor limits for this ESC are, and its electrical parameters? I can't find even such a basic parameter as BEC voltage and current. I would ideally like to connect Tekin Pro2 motor (which is a 4 pole motor). However, I have a very light car (1500g), which should help.
haplm is offline
Old 09-30-2016 | 06:49 AM
  #114
Woulvesbaine's Avatar
Is there a gen 2 with the built in receiver?
Woulvesbaine is offline
Old 09-30-2016 | 08:21 AM
  #115
Correct you can only change 5 parameters with older radio's.
There is no gen2 with build in receiver.
Not sure if it will come later.
Old 10-01-2016 | 02:35 AM
  #116
How the hell can i reverse the motor? Cant find any info on how to do that
boggiii is offline
Old 10-01-2016 | 11:00 PM
  #117
Usually the way you reverse motor rotation is through the radio and reversing the throttle channel, then recalibrating the speed control.
trigger is offline
Old 10-03-2016 | 07:44 AM
  #118
Hey guys, am thinking about getting a super vortex zero esc/rx to go with my mt4s radio. I like to tinker and think this would be cool. Any major ups or downs worth mentioning with these things ..pain in the ass to tweak or super convienent etc. etc.??? I currently use a Tekin RSX esc with hotwire 2.0 for setup changes. Any info would be greatly appreciated. Thanks! This would be used in 2wd and/or 4wd buggy mod class.
woods05 is offline
Old 10-04-2016 | 02:04 AM
  #119
+1 to this. Anyone who can share some more detailed experience with this ESC?
Does anyone know what the motor limit is? Can I run 4-pole motor with it (car under 2kg / 4lbs)?
haplm is offline
Old 10-06-2016 | 01:41 PM
  #120
I have tried to contact Sanwa, and this is what I've got:
This Message was undeliverable due to the following reason:
The user(s) account is temporarily over quota.
<[email protected]>
I really like their stuff, but it almost looks like they don't want to do any business. Missing information, email not working, no support forum, ...
haplm is offline
